The G-Body Swap Thread
Good luck to ya..
So far this is the direction I'll most likely be going in...
Motor mounts: Either Dirty Dingo adjustable mounts or Moroso solid mounts (Lower
mount: 62630, Upper mount: 62515) w/ Edelbrock 6701
Longtube Headers: hedman headers
Oil Pan: Retro LSX's custom pan for $395
Rework harness: RetroLSX for $500? Tune at Speed Inc?
Accessories: KWIK kit for the ALT and PS for about $300?
Cam: L99 cam reccommended by RetroLSX
Trans: I think I need spacer P/N: 12563532
Any better options? Missing anything? Thanks!
Here's where I'm coming from. SBC 406 w/ HSR.....
Camaro & Escalade VVT Cam (L92 & L99) Mild 220/234 .570/.588 116 L99 / L92 HO Cam Moderate 224/238 .578/.593 115 L99 / L92 SS Cam Moderate 230/237 .588/.607 111
That being said.. its still not cheap to retain the stock speedo..
http://www.rd-eng.com/pagetwo.html
Or.. You could go this route for 325.00..
http://www.abbott-tach.com/cablex.htm
But I needed a different tailshaft as my 4L65E from a 06 GTO didnt line up..
So for my situation..I went with the tailshaft solution to correct the fit with stock crossmember as well as the stock speedo..
If you go the route I did..
You need to give him your rear ratio and tire size and he can set you up with the right speedo gear.
His price was higher on the web page, but when I called to order it was 25.00 less (450.00 total) Plus 15.00 for shipping..
I never mentioned the web price.. I just asked how much when I called..
Ask for Doug..
Regards,
Matt
http://dirtydingo.com/store/American...306/index.html
is is what I have so far From doing a little site digging .ALT brown or black//STATER both red//DISTRIBUTOR red and TAC SIGNAL cream color...if anyone knows what I'm missing to run my standalone harness with aftermarket guages please let me know....
