The G-Body Swap Thread
Just did and LS7 '78 Monte. Use the Corvette filter/ regulator. The plug in factory style filter lines are availible at any parts store (got mine at NAPA) and ther are about 3-4 inches long. You will then use a compression union to AN fitting ( 3/8 and 5/16 availible from Street and Performance) Mark at S&P also sells the whole filter, fitting kit. Just plumb from there with AN fuel line. I used braided. Mounted mine on the rear crossmember between the coil springs on the front side. Easy setup.
speaking of wiring does anyone have a good source for information for wiring help. i'm moving my battery to the trunk in addition to the conversion. i need some diagrams or some type of wiring for dummies.
Keep in mind the important fact that i'm going to be deleting A/C, so i wont worry about mounting a compressor or having to re-locate it due to its position. I've heard that the compressor is really the hardest thing to get past- so if that's gone I probably have any option available, correct? (depending on what intake i want to run, obviously)
What about the aftermarket as well- i've searched around and have heard about LSx swap accessory kits, but haven't seen them online anywhere?
Thanks in advance!
kojo300zx@yahoo.com
The engine mounts are custom made but I have also used the "re-locator" plates that are commonly out there, that are supposed to put the LS engine in the correct "small block" position. Here is a pic were you can see the "plates" and the mount
here is a pic of the oil pan from the front
