The G-Body Swap Thread
The air conditioning needs to be retained. I've been looking at different headers trying to find what will clear the heater box, but I haven't seen a definitive set up to make this work.
We will most likely be using a GForce notched crossmember to allow for dual exhaust. Worst case scenario, we can just use the manifolds that come on the motor as long as air can be kept. Anyone with success in doing this, please share your setup.
Is anyone running a carbed motor with a stock hood? I'm guessing it's not possible based on the height of the single plane intake.
Pictures or it isn't happening! Lol pics please
I couldnt Use the BRP style because of column shift linkage issues and also I wanted to make sure I had plenty of room around other areas since I used John Bs mounts.
Below is a picture of the mock-up I derived from pictures I used from others that posted on the board and below that, the end result in 16GA 304 stainless, 1 7/8 primary.
The main items I wanted to and have achieved are:
1. Clear all obstructions (Z-bar, shift linkage, frame, control arms, Spark plug wires etc.)
2. Be able to slip them in without removing items or jacking up the engine.
3. Have bolt hole flanges for easy removal
4. Have O2 bung provisions for ECU and Wideband.
5. Make them stainless
.How low do they hang? looks like they would hang below the k-member.
I dont intend to make it a low rider and the CTS-V pan was already below the crossmember so not really a big deal..
While the design is similiar in appearance, every inch was done by eyeball directly on my vehicle and I assure you it is very different to not only fulfill my desire to have a set of stainless headers but ones that fit exactly to my specifications and clear all the items I mentioned before.
I was also looking at Johns effort (pic below) as a possible starting point but it was wayyyy too much of a geometry lesson for my taste as it looks to me that one of his goals was to have equal lengths. Also I opted not to use his effort as a starting point as it probably would have been a more difficult task to clear the Z-bar in my column shift..
I'm going with the BRP mounts and a set of F-body Pacesetters. I bought the cheap painted ones so I can beat them up cut and weld without having to worry about ruining a nice set of headers. I'll coat them later on. Also swapping my A/C box for a heater only box but I first have to fix the hole that UPS decided to create.
I think I asked this question in here before, but is everyone that's using an in-tank pump, using a stock un-modified fuel tank from an EFI G-body? I've heard people having problems with aftermarket replacement tanks not venting properly. I'd hate to have to cut into my tank if I can buy a cheaper factory tank from a junkyard.
Thanks.. I did do the PVC mock up but had a shop do the finished work based on my PVC model.. The second bung if for a wideband.. So yes A/F gauge..
Used a walbro in place of the stock FI pump
Sorry I really didnt give you a straight answer.. This thread pretty much sums up why I didnt use an aftermarket.. Hope this helps..
https://ls1tech.com/forums/conversio...tank-fast.html
Appreciate the link though I never even thought about searching here for it.
http://www.elcaminocentral.com/showp...1&postcount=19
