The G-Body Swap Thread
Old Jan 2, 2015 | 09:29 PM
  #1321
BanditDave's Avatar
Originally Posted by sethbeta
So do the current hooker swap brackets (12643hkr) work with the cts v pan, or is the Holley pan the only option?
I had asked that in the Hooker thread and we are unsure. I currently have the V pan only motor but bought the full shebang from Hooker for the GBody swap - my V pan has twin drains for a turbo setup I am not doing. Anyhow the holley/hooker setup sets the motor back .75" approx v. something like the carshop 1" set back plates. It would be very close and looks like it might, but I'd be concerned about steering arm clearances.
When I get everything in I'll do some measuring and mock up for you.
Dave
Old Jan 2, 2015 | 09:42 PM
  #1322
user 4737373's Avatar
I'm sure there would have to be other alternative pans that would also fit, but the time needed to identify them and verify their fitment was not accounted for as part of the development process.
Old Jan 2, 2015 | 09:45 PM
  #1323
Fry_'s Avatar
You can notch the back of the crossmember and use a F body pan also.
Old Jan 3, 2015 | 08:22 AM
  #1324
skylarkul's Avatar
The book " Chevy LS Engine Conversion Handbook" by Shawn Henderson has a whole section on oil pans - including measurements. It's the best single source I've found so far and covers virtually every aspect of a LS conversion. The book was written in 2011 and, at that time, he talked about a "LHX" oil pan available from BRP Hot Rods. Today, I can't find any other reference to the LHX pan. BRP Hot Rods offers a G-Body conversion kit but, they use the LH8 (Hummer H3) pan. Henderson commented that the LH8 pan wasn't suitable for some applications because the sump was so deep that it hung below the crossmember. The Holley pan wasn't out when he wrote the book but, now, that seems to be the best option - and one that I'm going to use. I'm going to use Dirty Dingo slider engine mounts - PN D-3550C.
Old Jan 4, 2015 | 12:33 PM
  #1325
HeadGames Dave's Avatar
been awhile since I played with her.
Got the headers on, going to do a full mock up engine in it before it goes away on Jan 24th to get turbo's mounted, intercooler and radiator. Trying to decide if I go cheap route to get the car running (th350) or wait till I have funds and put the 4L80 in it gutted for the fab work. Doing a 4.8 with twin borg 62's to get her moving.
Old Jan 4, 2015 | 03:01 PM
  #1326
my406cid's Avatar
So I have the dirty dingo adjustable motor mounts,ctsv oil pan ice man cross member,truck acc drive,holley a/c bracket. Also have quick ratio steering box. What size pulley has been used for p/s? Was gonna try a grand am p/s pulley which is 5"in diameter.what have others used?
Old Jan 4, 2015 | 04:38 PM
  #1327
bigmandengo's Avatar
Unless the quick ratio box is different than the standard box, the original truck pulley clears easily.
Old Jan 4, 2015 | 07:17 PM
  #1328
The standard run-of-mill power steering box used in G-bodies was the Saginaw 605 box. It has a bulkier casting than the quick ratio 700 series box in the area of the pulley to accommodate a drilled internal hydraulic passage that travels through the casting. Having the quick ratio box is a real plus when doing a swap in a G-body for clearance issues as well as for the improved steering performance it provides. You shouldn't have any clearance problems with the stock truck P/S pulley.
Old Feb 4, 2015 | 09:50 PM
  #1329
dynodanmanda79's Avatar
Anyone here have a problem wih the front suspension sitting a few inches higher with the engine swap? Seems like I remember this happening with my third gen camaro after I did the LS swap.
Old Feb 5, 2015 | 04:45 AM
  #1330
onebadbowtie86's Avatar
From my aluminum headed 383 my car seems to sit 1/2" to maybe 1" higher in the front with the all aluminum ls2. Would probably sit about the same with an iron blocked lq engine.
Old Feb 5, 2015 | 08:24 AM
  #1331
ryanleiker's Avatar
I asked the same question with my nova on my swap. is your hood and bumpers all back on the car? This can affect it a lot. Mine dropped back down when I got the rest of the body panels back on. Also, roll it back and forth a bit, because the tires may be holding the suspension up.
Old Feb 5, 2015 | 05:38 PM
  #1332
I was just thinking about that, my hood is back on but I don't have the bumpers back on yet. I now have a fiberglass hood and i'll be going with fiberglass front and rear bumpers. I also do not currently have a transmission in the car so that may play a big role in the raised front end.
Old Feb 5, 2015 | 06:03 PM
  #1333
Snapped a picture real quick of the difference. This is with stock suspension front and rear, complete 5.3 with front engine accessories, and no transmission. I'll wait till I throw the transmission in and see what it does, then i'll start with 2'' drop spindles and go from there.
Old Feb 5, 2015 | 06:43 PM
  #1334
BanditDave's Avatar
Looks sharp!
Old Feb 5, 2015 | 08:00 PM
  #1335
Originally Posted by BanditDave
Looks sharp!
Thank you sir!
Old Feb 6, 2015 | 04:42 PM
  #1336
jimmyg's Avatar
What wheels are those? Lookin for some wheels for my cutty
Old Feb 6, 2015 | 06:55 PM
  #1337
'87 Monte SS's Avatar
Yeah, same here as well. I'm not sure if it will settle down some after everything is put back on. This pic is when I had just finished dropping in the engine/tranny.
When I took the above pic, these items were not installed:
Hood, AC condenser, Radiator (plus coolant), Engine and tranny oil, AC bracket and compressor and alternator. I'd imagine that should drop it some but I can't see it returning to stock height.
Old Feb 6, 2015 | 08:26 PM
  #1338
I am running Boss 338's front and rear, fairly popular wheel. 18x9.5 with 295/45's in the rear and 18x8 with 245/45's up front.
Old Feb 16, 2015 | 01:53 PM
  #1339
Blackbuick 1987's Avatar
Wow a lot of info in this thread. I am working on a 5.3 swap into my 87 GN. My rods show up this week then off to the machine shop with the block and 317 heads, putting compstar 6.125 rods in with wiseco 5.3 pistons. I have a stage 2 Extreme Automatics 200-4R that I am gonna use initially to get the car driving and then will save for a 4L80e over the next winter.
Old Feb 19, 2015 | 11:06 PM
  #1340
No kidding...it took a while to go through all 67 pages!
