The G-Body Swap Thread
Old Aug 23, 2014 | 10:16 PM
  #1301
BOXCHEV's Avatar
Originally Posted by onebadbowtie86
I have read that the f body pacesetters will work in a g body, just that the drivers side collector is kicked out.
Will any other f body headers also work, or just the pacesetters?
https://ls1tech.com/forums/conversio...dy-update.html
Old Aug 30, 2014 | 07:58 AM
  #1302
mikesimpalass's Avatar
Can i hook my engine speed signal from the pcm directly to my factory mcss tach? Or do i need to wire it like this?
http://www.lt1swap.com/lsx_tach.htm
I know the pcm tach output has to be changed to 8 cyl mode, but i didnt know if my pcm has the power to run my factory tach.
Old Sep 9, 2014 | 06:59 PM
  #1303
jimmyg's Avatar
Default Any pics of g bodys with 18 in irocs?
Thinking of 18 in irocs on my 83 cutlass .been looking everywhere but can't fig out backspacing and also need to fig out fattest tire I can put on back without notching frame the ones on ebay are 4 in bs if any body has them I would love a pic everybody online is rolling on 22-24 I saw one with 17s that didn't look to bad anyway my swap is a 2010 ly6/4l80e and prob a ford 9 . Also what do u think is a good gear to run with combo?i was thinking 373s I'm keeping vvt and went with mast motorsports ss cam and spring combo supposed to be 509hp now I'm just waiting for holley to release new mounts and headers going with psi harness ls3 intake holley front drive. car is all original with 80k was stored in a barn for 20 yrs black with tan buckets going to be sick!!!
Old Sep 9, 2014 | 07:24 PM
  #1304
89LS1FOXER's Avatar
A few updated pics of my 79' 2dr Malibu progress, adding some LSA fun
Old Sep 10, 2014 | 02:44 PM
  #1305
Fry_'s Avatar
Holley front drive wont clear with there new mounts.
https://ls1tech.com/forums/attachmen...-tech-data.pdf
Old Sep 10, 2014 | 07:21 PM
  #1306
jimmyg's Avatar
That sucks but it will prob save me $$ I have the truck front drive but no ps pump I could use the r4 Ac bracket and ps pump with smaller pulley I just want something nice I've been busting my *** trying to pay for this any ideas that won't break the bank? So confusing
Old Sep 10, 2014 | 07:52 PM
  #1307
user 4737373's Avatar
I'm glad to see that the tech info on the new Hooker system of components is getting read by yourself and others Fry. As the document states, the Holley and OE Corvette accessory drives are not compatible for use with the new Hooker engine mounting brackets as the low engine height puts the power steering pulley on those set-ups right into the power steering box fittings, even when using the smaller pulley that some have been known to use.
In order to take advantage of the improved engine/transmission installed geometry that the new mounting brackets provide, you need to use a truck, F-body or GTO accessory drive set-up.
Old Sep 12, 2014 | 11:00 AM
  #1308
BORDERBUM's Avatar
What components system seems to work easily with a 5.3 truck setup in a g body. I have a 84 MC SS and am looking for an easy setup where I can bolt the motor in and then have my guy wire it.
Thank you for your replies in advance.
Jeff
Old Sep 12, 2014 | 12:14 PM
  #1309
Jeff
The new Hooker G-body LS swap components combined with the Holley 302-2 oil pan will allow you to drop that 5.3L truck engine right in and not have to worry about finding a bunch of other parts that may or may not work together in an optimized fashion. The exception to the bolt-in compatibility is the truck low-mount A/C compressor, which can be installed by notching the frame if you really want to run it. The other option is to use a top-mount compressor relocation bracket like those available from Holley for the R4 and Sanden compressors.
Old Sep 13, 2014 | 11:57 AM
  #1310
BORDERBUM's Avatar
Thanks Toddoky! That looks like a great system for what I need. I read your other thread on this subject. Great news. Appreciate your time.
Old Oct 2, 2014 | 08:56 PM
  #1311
87luxsprt's Avatar
Originally Posted by 85mcss
got mine all mounted up in the car last night.
1985 Monte SS
$100 160k 2003 5.3 LM7 from JY with 0411 PCM (No harness)
PSIConversions harness
Moroso solid SBC mounts & EBay 1" setback swap plates
H3 "Muscle Car" Oil pan
Stock truck accessories & intake
LS1 cam, PAC springs, LS9 MLS headgaskets, KMJ studs
Drivers side Fbody manifold
Passenger side truck manifold
04 4L80E w/ transgo HD2
Stock 80E converter at this time. Soon to be 4k CircleD Triple Billet
Iceman crossmember
Total spent for engine swap: $1356
I already had the 80E in the car
the Passenger valve cover rear coil mount boss needs to be hacked off as it just barely touches the AC box but that's about the only interference I've ran into. Still haven't tried the hood but it looks promising. Oil pan does hang lower than I would like. I'll get some measurements of that at some point.
WOW! only 1K on the swap. thats what am talking about, QUICK QUESTION IS WHAT IS EVERY ONE DOING FOR THE DRIVE SHAFT! CUSTOM MADE???
Old Oct 3, 2014 | 10:46 AM
  #1312
cfaluck13's Avatar
Hey 89ls1foxer!!
I'm planning on putting my lsa blower in my G body as well. An '86 elky.
Have you figured out What accessories your going to use? What about a/c ?
I'm figuring on using a high mount ac compressor but Idk if the stock lsa accessories would work down in our frame rails.
I was thinking about using a corvette accessory drive but Idk if that will clear the blower.
Old Oct 4, 2014 | 01:53 PM
  #1313
tdishon's Avatar
I put the LSA in my 86 GN. Fit great with Spohn/f-body mounts. I used the alternative GM performance accessory drive kit that puts the Alt up higher. No issues with steering box at all. Plenty of room. I used the Alan Grove lower corvette (Same as LSA) A/C mount for the Sanden SD5.
I notched the frame to tuck in the compressor. I don't think you can mount the A/C high on the passenger side due to the supercharger tensioner(I may be incorrect)
My $.02
Old Oct 6, 2014 | 06:43 PM
  #1314
cfaluck13's Avatar
Awesome thanks tdishon!
That's exactly the info i've been looking for. Sick build btw!
Old Oct 11, 2014 | 12:27 PM
  #1315
6togo's Avatar
Here is some pics of the oil pan i had custom made to my specs by Doug Lee @ Propans great guy to deal with and awesome work!
I took some ideas from a few different pan designs i seen and had him roll it into one it holds 7qts in the pan plus the filter which is a stock screw on type and it has trap door's in there also just cant see them in the pics!
Attached Thumbnails The G-Body Swap Thread-photo-26-.jpg   The G-Body Swap Thread-photo-25-.jpg   The G-Body Swap Thread-photo-24-.jpg   The G-Body Swap Thread-photo-27-.jpg
Old Dec 3, 2014 | 06:13 AM
  #1316
Houston_t's Avatar
never mind
Old Dec 16, 2014 | 11:58 PM
  #1317
lessthan0's Avatar
Default 82 El Camino - Radiator?
Putting an lm7 (ls based gen III) Into my g body. Anyone have any suggestions on radiator and fans? Thanks!
Old Dec 17, 2014 | 09:33 AM
  #1318
tdishon's Avatar
I have been running a Ron Davis and have had zero issues.
Old Dec 29, 2014 | 02:30 PM
  #1319
jtotheizzo's Avatar
It lives:
Pic under the hood
Old Jan 2, 2015 | 08:43 PM
  #1320
sethbeta's Avatar
Default oil pan question
So do the current hooker swap brackets (12643hkr) work with the cts v pan, or is the Holley pan the only option?
