The G-Body Swap Thread
Old Feb 19, 2014 | 09:16 PM
  #1101
6LITEREATER's Avatar
Thanks I'll read through tonight!
Old Feb 19, 2014 | 09:17 PM
  #1102
Originally Posted by mOtOrHeAd MiKe
And where did you source these magic lines from?
Local shop probably. Took me forever but I found a place. If you have fittings and lengths I can get you some made. No idea on price yet as haven't gotten to that point on mine...
Old Feb 20, 2014 | 11:34 AM
  #1103
85mcss's Avatar
got mine all mounted up in the car last night.
1985 Monte SS
$100 160k 2003 5.3 LM7 from JY with 0411 PCM (No harness)
PSIConversions harness
Moroso solid SBC mounts & EBay 1" setback swap plates
H3 "Muscle Car" Oil pan
Stock truck accessories & intake
LS1 cam, PAC springs, LS9 MLS headgaskets, KMJ studs
Drivers side Fbody manifold
Passenger side truck manifold
04 4L80E w/ transgo HD2
Stock 80E converter at this time. Soon to be 4k CircleD Triple Billet
Iceman crossmember
Total spent for engine swap: $1356
I already had the 80E in the car
the Passenger valve cover rear coil mount boss needs to be hacked off as it just barely touches the AC box but that's about the only interference I've ran into. Still haven't tried the hood but it looks promising. Oil pan does hang lower than I would like. I'll get some measurements of that at some point.
Old Feb 20, 2014 | 01:03 PM
  #1104
G-Body's Avatar
sawzall wielding director
The lines for my first swap I had custom made at a local A/C shop. I had re-used the factory condenser with drivers side connections so I wanted it to be aluminum hardline across the radiator.
The other swap that I did I made sure to get the cutlass condenser so that I could just run rubber a/c lines. I can`t remember which place I bought the fittings from but I just googled for them. Mastercool makes an a/c line crimper so that you can crimp the ends on yourself, or some napa stores can crimp the ends for you.
If you have the older red/blue truck PCM like I do, I just re-used the g-body a/c wiring and controls and jumped out the low pressure switch on the truck harness, and then hooked the a/c request signal (red pin 17) to the +12v side of my a/c clutch. That way whenever the clutch is engaged it turns my idle up and turns the radiator fan on. If I was doing the wiring again, I would probably hook up the wire from the g-body A/C controls directly to red pin 17, and hook the g-body low pressure switch up to the PCM. Then if you use the underhood fuse/relay center the rest of the compressor wiring is taken care of already. If you have the newer blue/green pcm with the serial data request for A/C it gets a lot more complicated. I asked HPTuners to add in the parameter so we can set the PCM to accept a 12v A/C request......but I never got a response. As of now you have to either mod the PCM with another editor, or keep the pcm out of the a/c status loop
Old Feb 20, 2014 | 04:20 PM
  #1105
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Thanks for the feedback.
I am really tempted to see if I could adapt the whole F-body system to the car.
Old Feb 24, 2014 | 09:18 AM
  #1106
samckitt's Avatar
Where's the best place to get the Hedman/BRP headers?
Old Feb 24, 2014 | 06:28 PM
  #1107
ARH has a stainless swap header now too... no need to buy mild steel any longer.
Old Feb 25, 2014 | 05:57 AM
  #1108
Would have been running this weekend but the new turbo was not the one I ordered so it didn't fit (smaller, everything was 1/2" off). Here it is mocked up though...
Things will get changed a little (like that radiator hose) and bead rolled sheet metal will line the engine bay but she's getting there (after MONTHS of issues with parts suppliers )...
Old Feb 25, 2014 | 07:56 AM
  #1109
1970camaroRS's Avatar
Here's my work in progress.
Attachment 725110
Old Feb 26, 2014 | 09:13 PM
  #1110
After arguing witht the turbo company via e-mail yesterday that the AR (whatever you call it, back side down pipe attaches to) was NOT the same size as my original (that was bad out of the box but we mocked everything up with it) they finally said just bring it down.
It wasn't the same. Ten minutes later that had a new one for me and we got it all bolted up today . Ran out of time at the shop but Saturday we'll re-do the radiator hose, clamp it all up, attach the exhaust, run the vacuum lines and catch can lines, fix a throttle cable issue, download the tune and fire her up!
Old Feb 27, 2014 | 06:55 AM
  #1111
6togo's Avatar
Does that pro flo intake clear the stock GN hood?
Old Feb 27, 2014 | 12:32 PM
  #1112
StrokerTA's Avatar
Does anyone have pictures of an "H3" pan, or an Fbody pan in the chassis?
Also how many guys have notched the cross member and made it tubular?
Similar to this.
Old Feb 27, 2014 | 03:01 PM
  #1113
Not even close lol. I took the stock hood chopped it up and made the stock bump 60% larger.
Old Feb 27, 2014 | 03:08 PM
  #1114
BOXCHEV's Avatar
Possible to get under there and snap a pic of the motor mounts?
Old Feb 27, 2014 | 04:47 PM
  #1115
^^I'm going to go back and try to make a parts list for everyone. They were just e-bay motor mounts and they sit high which is good because I just used a truck A/C and H3 pan and didn't have to notch anything and it all clears.
Was able to use a couple mounting holes and drill a couple but ended up sitting high on the frame so bent the top of the tabs down and welded the whole mount to the frame...
Here's the thread (should be pics in there actually of the motor mounts)...
http://www.turbobuick.com/forums/thr...e-mods.398984/
Also here's the modded hood...
Old Feb 27, 2014 | 05:40 PM
  #1116
llorracs93s10's Avatar
My fbody oil pan with a 1 inch set back plate is still touching the engine cradle on the corners of the pan. Little maneuvering and it will fit better. I'd suggest getting one of the holley or autokraft pans.
Old Feb 27, 2014 | 05:49 PM
  #1117
StrokerTA's Avatar
Anyone used the Holley manifolds for a turbo build in a G-body?
http://www.jegs.com/i/Hooker-Headers...rentProductId=
Old Mar 1, 2014 | 02:24 AM
  #1118
^^I don't think the flange would clear the brake block on the driver side...
Old Mar 1, 2014 | 07:04 AM
  #1119
StrokerTA's Avatar
Turbo application with V bands. Forward facing.
Old Mar 1, 2014 | 08:26 AM
  #1120
StrokerTA's Avatar
From what I've read, the truck manifolds won't clear because the drivers side truck manifold that gets mounted forward facing on the passenger side has a bit of a kick out on it that hits the frame.
These Holley manifolds seem to be more inline, was thinking they would work nicely..
I'll have my motor mocked up next week, so I'll figure it out then I guess.
