The G-Body Swap Thread
The truck accessories will fit under the stock hood with the clamshell mounts. The BRP ones however will not clear. You can use the car intake with the truck accessories with a kit someone sells on here.
Merv, did you have to massage the Hedman's to fit properly? I have a set of $260 Pacesetters here and with the BRP mounts they rub the crossmember, trying to balance the cost of selling these and getting BRP's, or using what I have, smashing them up, and getting them coated with flanges welded onto them.
And yes still got the truck. I'm looking to ***** it as much as possible on the shows as I can. Trying to finish her up this spring so I can be done with it and love onto getting cash for life and the Monte!
https://ls1tech.com/forums/new-produ...-270-99-a.html
The kit basically has you take the idler off and relocate it, and put the new style truck water pump on with a different belt. You only need the LS1/LS6 injectors when going to a car intake. I think you can make the car ones work on the truck intake somehow but not vice versa.
I'm not really sure about p/s pulley interference, I bought the KWIK brackets and used a LS1 FEAD that I pieced together from this site. Then bought the PS pump with the smaller windowed pulley off their site. Money isn't really an issue with my build anymore though
https://ls1tech.com/forums/parts-cla...l#post14296784
I've looked and found the Iceman 4L60E crossmember fits pretty nicely, but I'm wondering about the G Force one. My dad has one in his 442 and it's a really nice piece.
