The G-Body Swap Thread
I tried really hard to not buy new parts, but when I did I showed no loyalty to any particular vendor - I searched the web with part numbers to find who had the new parts cheapest.
engine = 1300
motor mounts = 75
intake & MSD = 650
carburetor = 275
headers = 255
starter = 60
fuel pump = 90
fuel regulator = 100
crankshaft spacer/bolts = 75
misc hoses, belt, fittings,clamps, fluids etc = 300
so $3000 or so?
you can re-use a lot of your own stuff like the radiator and maybe the hoses, battery etc.
I'm carbureted, I figured the fuel injection route might be more $$ because the tuning and flashing the ecm etc, etc
http://cgi.ebay.com/ebaymotors/CHEVR...item255ec3facd
I know it says most truck motors but I just wanted to make sure. Is it a stock factory intake or a aftermarket one?
I have some completed pictures of things like my headers I should be able to post up sometime this weekend. Having a bit of difficulty NOT wanting to drive the car haha. I still have my PCM on the passenger floor and I really don't care because I can't stop driving the car. Over 8 days straight of driving it and still not an issue I haven't fixed easily.
It still has the whole drivetrain from rear to d/s to trans and motor. Also has the complete wiring harness and ecu. He wanted 1500 for the motor/trans wiring and ECU. Can that computer be used for a swap into my monte and eventually using a car intake? I know some computers arent able to be used for certain swaps, or atleast i was told of it.
Im going to look at it sunday in person but hes supposed to be sending me pictures today so i can post them up for you guys to investigate. One thing is that it is still in the engine cradle.
Ok so heres my question, is it worth to keep the 12 bolt to fit into the monte carlo (85 mcss) with shorten tubes, new axles and weld both rear trailing arms tabs to diff/spring mounts....or sell the complete rear for money off the price of the purchase? And same goes with the d/s....is that d/s somehting i could use since id be using the trans from it and possibly the rear? Anyways, heres pictures of the motor/trans and others!
Took as many pictures as I could for you guys. I have the vin number if needed for more info on the motor. Also but I do know it was a 2003 chevy express 2500 van. What you all think?
