The G-Body Swap Thread
#206
sawzall wielding director
I have floor shift, but the column controls my indicator. I had to bend the Z bar flatter and then bend the lever than comes off of it to the outside of the car to get it to clear the exhaust. To make the rod from the column bolt up and follow the new arc I cut the end of it off and welded a bolt on so that I could use a heim joint on the end.
#207
Thanks for the info guys. I'll see what I can work out. I've got a buddy helping me out with this as well. I had ordered a kit from lokar that uses a cable and a bracket to run the cable on the other side of the column but it won't work. Worse comes to worse I guess I'll put one in the floor, but I kinda like the idea of leaving it on the column. Thanks again.
#209
I have John Bs mounts and wanted to go with the BRP header but dont have enough info to pull the trigger yet..
If anyone has already.. The BRP headers with mounts that are placed close to the stock position.. and could post some pictures of the driver side area to where the column shift linkage comes down.. It would be appreciated.
To date I have no idea if its going to be a major deal or a simple tweak such as massaging the linkage as I had to with the standard motor and long tube headers for same application.. 800+ dollars for headers is a bit hard to swallow when you come to find out that theres no way in heck there going to fit with a column shift... and to tranfer over to console shift is not cheap nor real simple either
#210
Reason I ask is because I have the same ( 86 Monte with Column Shift)
#211
Not sure how close the position of my motor is to the original, but the brp kit i used actually bolts into the same holes as the factory mounts. If you'd like, I can take a picture or two of the linkage area around the stock f-body manifolds. I've also not forked out the money for the headers just yet.
#215
Thanks G-body! I appreciate it..
One last question.. Do you happen to have a picture with a view from the angle posted below?
BTW... other than the fact that I'm out of the country currently.. Normally, I'm very close to where you are.. My old stomping ground ( Downers Grove) where I went to highschool.. The next question would be South? North? and what year? lol
Anyway.. just mentioned as it would probably be nice to shoot the sh%t with you some time.. With all my spare time..
lol
Thanks again.. Matt
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Thanks again.. Matt
![](http://img411.imageshack.us/img411/6929/montess.jpg)
#216
I wish I would have done an LSx motor in the first place instead of an LT1. But I now have the LT1 running pretty good, & the 6 speed is a blast to drive. So instead of putting more $ in the LT1 I think I am going to keep my eyes out for a 6.0L truck engine, have it rebuilt with some different heads & then I will have to find another 6 speed & change it over.
#217
I guess I am the newest to the G-body LS1 club... I currently have an '88 MCSS with a 700Hp 350ci using a ProCharger. The car has been 129mph in the 1/4 on a 640hp tuneup. I also did a Tremec TKO conversion about 8yrs ago (which I will be keeping with the LS1. My plans are to install a mostly stock LS1 in the car for now with a carb and distributor conversion, and fab a single turbo setup for it...looking for around 520ish to the tires for now. This SHOULD be done by the end of this winter... over the next year or two (as $$ allows) I'll build up a better engine and shoot for 650-700 at the wheels. I'll keep throwing some updates out as they come! Here is what I'm starting with...
![](https://img241.imageshack.us/img241/948/img0380cg3.jpg)
#219
It is a 2.5" straight dual system (no crossover) using Dynomax Race Magnum mufflers. I actually HATE the sound...too "poppy" for me. When I go with the turbo I'll be changing the whole system.
#220
Finally got the car driving around on saturday so went and got the exhaust put on. Drove bout an hour to a drag strip in it and ran a 8.1 in the 8th with the factory tune and leaving somewhat easy. Pretty happy bout it myself. Anyone else have any times I can compare to with in a car with similar mods (gear,3600 stall, and cam)?
