The G-Body Swap Thread
Old May 24, 2016 | 12:59 PM
  #1641
samckitt's Avatar
Originally Posted by bigmandengo
The spohn mounts ended up mounting the motor very close to where it was with the setback plates. I didn't have to change driveshafts, trans cross member, etc.. Regardless, my truck compressor still has around 3/4" clearance to the frame.
This guy mounted a Sanden down low with Corvette accessories and a blower. I think he used the Alan Grove setup.
https://ls1tech.com/forums/conversio...onversion.html
Looks like I will be notching the front crossmember. Wonder if I can do that with the engine in the car. Ugh.
Old May 24, 2016 | 10:07 PM
  #1642
atctkd's Avatar
I went to the local upull it yard and got alternator and power steering pump on the truck bracket, and the ac compressor all for just under $100...might be cheaper than Ebay. Just an idea
Old May 25, 2016 | 07:19 AM
  #1643
jimmyg's Avatar
Oh ya.
Old May 26, 2016 | 02:54 PM
  #1644
G-BODY-JAMES's Avatar
Originally Posted by jimmyg
oh ya.
atta boy!!!!!!!
Old May 26, 2016 | 02:58 PM
  #1645
NEW VIDEO ON MY YOUTUBE CHANNEL COMING SOON!!!! GETTING COMPLETE DYNO TUNE THIS SATURDAY TO GET SOME NUMBERS ON PAPER AND FINALIZE THE BUILD......FOR NOW
ps. jimmy that whipple is looking siiiiiick!!!!
File Type: mov
Old Jun 10, 2016 | 01:54 PM
  #1646
HeadGames Dave's Avatar
does the 03' Escalade pedal work in the G body for Drive by wire?
Old Jul 6, 2016 | 10:26 AM
  #1647
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Does anyone have pics of PCM/ECM placement when using a factory or modified 99-02 F-body engine harness?
Mine wants to share the same location as my A/C dryer.
Old Jul 6, 2016 | 10:53 AM
  #1648
carfreak07's Avatar
Old Jul 6, 2016 | 12:49 PM
  #1649
Thanks! It is as I feared. Looks like it was a good thing I kept all of the F-body A/C parts.
Old Jul 8, 2016 | 08:28 AM
  #1650
Brian Dorsey's Avatar
Will the truck acc fit under a stock cutlass hood on a 87 using the hooker mounts?
Old Jul 8, 2016 | 09:08 AM
  #1651
user 4737373's Avatar
I'm not sure about a Cutlass hood, but it does under a Monte Carlo SS hood.
Old Jul 9, 2016 | 08:07 PM
  #1652
jimmyg's Avatar
Yes I ran my cutlass like this for a while
Old Jul 10, 2016 | 01:21 PM
  #1653
L92 OLDS's Avatar
Jimmy, Your blower looks sick! It also looks as tall as my factory intake. Do you know how much hood clearance you had with the truck set up in your Cutlass with the Holley mounts? At first, my hood hit the throttle body and alternator on my L92 due to a known issue with short Energy Suspension body mounts for the radiator support. With 1" aluminum spacers I added, the engine and alt now clears but I'm still worried about little to no clearance combined with engine movement. Aluminum hoods for these cars are rare and they dent easily.
Old Jul 16, 2016 | 09:56 PM
  #1654
jimmyg's Avatar
What are you using the truck intake? I had a ls3 intake but my alt fit fine with the truck bracket. I had the big alt and I still had 3/4 inch. Even with the whipple , the factory hood closed but hit. I prob could of modded the hood frame, but I had already bought the 2 in cowl from g body parts. I think the whipple is 101/2 in off the valley cover. So anything shorter that that should work. I also had the aluminum hood , the new one weighs a ton compared to the old one
Old Jul 19, 2016 | 08:08 AM
  #1655
anyone have one of these in your car? Pics of the install? or installed?
Old Jul 19, 2016 | 08:57 AM
  #1656
JoeNova's Avatar
Restricted User
Originally Posted by witman69
HI guys: Longtime lurker here, but I finally bit the bullet and picked up a 6.0 LQ9 from a local shop. I painted it, then bought a CBM motorsports harness, and am planning to get a CTSV oil pan and dipstick.
However, I'm not sure about accessories. I'd like to have AC someday, and am happy to use stock corvette stuff. Is that a decent plan, or do I need to go out and spend 1500 bucks on accessories? Thanks! Jerry W. 86 Monte SS
I used stock truck accessories on my last G body swap.
Old Jul 19, 2016 | 11:52 AM
  #1657
Originally Posted by carfreak07
is that a truck intake?
Old Jul 19, 2016 | 11:57 AM
  #1658
JoeNova's Avatar
Restricted User
That's been shaved, yeah.
Old Jul 20, 2016 | 08:57 PM
  #1659
witman69's Avatar
Default Latest Header Advice?
Hi Guys: The LS is coming together, still need to find some truck Accys, Throttle cable (Lokar)? with a Kickdown bracket for my 200r4, and an adapter, Camaro Water pump, and an idler pulley I think. I need to start planning the exhaust now. I have Tubular upper A arms which gives me some extra space. Are our options still limited to F body and the new hookers? Any advice much appreciated!
BR Jerry
Originally Posted by onebadbowtie86
I know I would really appreciate it, and I'm sure others will also. It seems like the new hooker headers are the only ones that dont drag the ground, but I dont really want to drop the money on them if they wont fit.
Attached Thumbnails The G-Body Swap Thread-wp_20160720_007-1-.jpg   The G-Body Swap Thread-wp_20160720_001-1-.jpg
Old Jul 21, 2016 | 01:17 PM
  #1660
ryanleiker's Avatar
BR Jerry
You're going to try to put truck accessories/truck bracket on with that intake?
