4wd s10 ls1/ls2 swap?
has anyone done a ls1 or ls2 swap into a 2nd gen 4wd s10. If you have or know anyone who has done this could you please give me whatever information you have on this. also i was curious as to wether or not you can pass emissions with the conversion. i am in arizona but will be moving to california shortly.
I've done it....
Oilpan and Exhaust are the 2 biggest things to address.....
Republic of Kalifornia emissions are tough to deal with. I'm not sure that there is a legal V8 swap for a S10.
'JustDreamin'
'JustDreamin'
Originally Posted by JustDreamin
I've done it....
'JustDreamin'
'JustDreamin'
Originally Posted by BLK02TA
What about for a 2wd?
There's also a 30+ page S10 swap thread, that has most of the 2wd answers. You might spend some time and read it. I know alot of it is BS, but there is some useful info in there......
2wd doesn't have to clear the front differential, which is good. But you've still got to modify either the crossmember or oilpan to clear.
Exhaust is less of an issue, since you can get headers for a 2wd swap (I think they're 1 5/8" tubing, so probably a bit small, but...)
But the Republik of Kalifornia's emissions laws are fairly strict. You'll need to research whether you can get an LS1 V8 powered S10 through emissions in CA. Because if it fails emissions, you've either got to fix it, move it out of state, or take it off the road (because the emissions ****'s can take your plates). I live in Maryland, and I've got hoops to jump through, they're just not nearly as bad as Kalifornia.
'JustDreamin'
Originally Posted by zz4camaro1980
Im not sure what year the S10 was but Linginfelter did a TT427 swap into a 4WD S-10 about 6 yrs ago. Sorry, im not sure what magazine I saw it in.
An untold amount of labor went into that project.
The following users liked this post:
dave watson (04-09-2020)
