oil pan torque specs?
they are long and skinny.
not to be confused with other, much larger bolts.
ahah.
but seriously....
use 4 small dab's of RTV sealent where the front and rear covers meet with the pan/bottom of block
also make 100% SURE THE REAR OF THE PAN IS EVEN WITH THE BACK OF THE BLOCK
im gonna repeat that. the rear of the pan needs to be PERFECTLY STRAIGHT with the back of the engine. it can NOT stick past the rear of the engine.
the pan on the lsx motors are structural parts of the engine. the factory spec says its allowed to be within .25mm sticking FORWARD of the rear but NOT sticking over the back of the engine. reason being is the transmission sits perfectly flush with the oil pan, and if it sticks past the rear of the engine you can crack the pan when installing the transmission.
