killer 71 c-10
Old Aug 5, 2007 | 02:32 PM
68shortstep's Avatar
how your ment to mount the tank is with a bolt and nut on the back side... almost impossible to get the nut on with the bed on... so i welded the nuts to the frame so you'll actually be able to take the tank out without a head ache.....
it doesnt hang down low at all, as a matter of fact, you'll probley wont even be able to see it once the bed is on..
Old Aug 5, 2007 | 02:36 PM
fuel line ran today, held on with .5" insulated cushined clamps... also finished up installing the trans lines clamps....summit sent the wrong fittings, so i gotta wait till next week to mnt the fuel pressure reg/ filter and plumb it up...
also so i dont leave ya hanging to long on the guages here they are.... i had to get 2 turn signal indicators for ya , also im gonna put the high beam indicator in the tach just below the '40' (to give it that stock feel), and i gotta add a red check engine light.... but heres what i have so far... the black wires are grounds, and will be hooked up to the quick-connect when all the mentioned lights get put in..also these wires are matching color code for the painless wiring diagram..
Old Aug 5, 2007 | 02:37 PM
installed the hidden receiver hitch, gas tank will not even be visable from the rear, so the stock look will be retained..and installed the rear disc brake kit.
Old Aug 5, 2007 | 02:44 PM
and here is just to get the post count up.....
Old Aug 5, 2007 | 02:49 PM
Rantheman's Avatar
hey nice project.
Old Aug 5, 2007 | 02:50 PM
killer is finally done with mocking everything up.... got the rear disc brake kit installed , the fuel system was completly mocked-up as well....once it was all together, i started tearing killer down to the frame....will be gone to the sandblasters ....
and here is a sneak peak of this 'coolness'....
Old Aug 5, 2007 | 02:51 PM
Old Aug 5, 2007 | 04:26 PM
transam5.7lt1's Avatar
Those are some skills! Very nice craftmanship! Very nice project as weel as your 68', very cool, keep it up!
Old Aug 5, 2007 | 04:35 PM
killer71's Avatar
Hey guys this dudes talent is off the planet. His skills are unlimited and he just sorta fell into my lap...boy was I lucky when I came across him!
Old Aug 5, 2007 | 07:31 PM
Compressor Surge's Avatar
Awesome project!!! Hey what headers are those? What chassis are they meant to fit?
Old Aug 5, 2007 | 07:52 PM
killer71's Avatar
headers are for a 00 camaro/firebird brand is pacesetters....
Old Aug 5, 2007 | 09:14 PM
  #32
ls1290's Avatar
Dumb Ass Vette Moderator
Originally Posted by 68shortstep
i mocked up the dual row, finned, frame mounted trans cooler... useing AN fittings and -6 braided line.
I would think about adding another transmission cooler or get a fan to provide some good air flow across the single cooler. The 4L60E needs as much cooling as it can get.
So far things look very good. I am impressed with the level of detail and attention you have put into the project
Keith
Old Aug 5, 2007 | 09:51 PM
  #33
this cooler is designed to disapate heat by haveing BOTH internal and external heat dissipating fins also this heat sink design produces high heat transfer with minimal airflow... unlike the traditional radiator mounted ones..... haveing said that it is designed for a non-lockup converter trans cooling needs, so with a lock-up converter, it should work out really well..
Old Aug 6, 2007 | 02:29 PM
  #34
350SS's Avatar
burn
Old Aug 6, 2007 | 02:38 PM
  #35
Originally Posted by 350SS
burn
Old Aug 6, 2007 | 02:39 PM
  #36
Nine Ball's Avatar
LS1Tech Co-Founder
very cool project truck. Let me know how much you will sell it for when you are done with it, it is even my favorite color combo
Tony
Old Aug 6, 2007 | 03:28 PM
  #37
killer71's Avatar
Whatcha Give?
Old Aug 6, 2007 | 04:00 PM
  #38
I have that same trans cooler on my truck (though a bit shorter) and it keeps it plenty cool. I've got it mounted under the core support, so it gets plenty of airflow.
You can just BARELY see it under the radiator here:
Real crappy pic of how it's plumbed:
Old Aug 6, 2007 | 04:27 PM
  #39
got all the pieces back from the sandblasters,they turned out great, and headed to the powdercoaters ......
Old Aug 6, 2007 | 04:34 PM
  #40
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
EXCELLENT.. .....great pics also... will be a cooool ride.
