killer 71 c-10
Old Aug 6, 2007 | 07:04 PM
  #41
jkade72's Avatar
Originally Posted by 68shortstep
and here is just to get the post count up.....
How much does she get a hour to help out around the shop? I can't afford much Glad to see you making progress and it looks great. I didn't know you where a member over here.
Later, Kade
Old Aug 6, 2007 | 07:22 PM
  #42
350SS's Avatar
Sorry, tv quote.
Just thought you did a good job explaining why you chose the trans cooler you're using
Old Aug 7, 2007 | 01:18 PM
  #43
killer71's Avatar
Hey 68ss, the air induction tube and the differential cover is on it's way...just got back from the post office!
Old Aug 7, 2007 | 01:21 PM
  #44
killer71's Avatar
Do you have a link on the foose wheels you have and the grey as well?
Old Aug 7, 2007 | 01:32 PM
  #45
rao's Avatar
rao
Looks great.
Old Aug 7, 2007 | 01:39 PM
  #46
IOwnCalculus's Avatar
How's the clearance on the driver's side of the frame with those headers? Are those the ECE mount towers?
Old Aug 7, 2007 | 09:22 PM
  #47
68shortstep's Avatar
i got them from showcarsupply.net they are working on there site so give them a call 612-867-6120
Old Aug 7, 2007 | 09:24 PM
  #48
read this
http://67-72chevytrucks.com/vboard/s...d.php?t=197347
Old Aug 8, 2007 | 10:00 PM
  #49
started assembling the frame today...majority of the day i spend cleanig steering parts and cleaning/ sanding brake lines... the new rear ECE trailing arms are SWEET, they are totally boxed and are a heavy guage, i know this cause they are HEAVYYYYY..... installed front x-member, trailing arms, fuel lines, brake lines... also brought over a buddy of mine to lend his hand on the cab...
Old Aug 8, 2007 | 10:16 PM
  #50
Numba1Stunna's Avatar
wow man you do amazing work keep it up and good luck
Old Aug 10, 2007 | 09:59 PM
  #51
getting some more assembly stuff done, while waiting on the suspension stuff to arrive...
got the steering box, intermittent shaft, ideler arm(still need to add washers under the head of the bolts), tie rods painted and installed, trans cooler on, and fuel cell mounted and plumbed..
Old Aug 11, 2007 | 10:03 AM
  #52
billyjo's Avatar
Good looking project, should be sweet when it's complete.
Old Aug 13, 2007 | 09:36 PM
  #53
alright i got the engine/trans installed....also ran the wireing for the rear (tail lights, turn signals, fuel sending unit, and fuel pump) kinda hard to see, but its held on with .5 insulated cushin clamps below the fuel line.... i also used factory style quick-connects, again keepin with the factory wires colors where applicable... i kept the factory round connect at the very rear x-member... i still need to add the protective wire loom over the exposed wires at the fuel tank, i know...and just for visual progress i put the radiator support on, i need to wash it tho, its dusty....
Old Aug 14, 2007 | 11:52 AM
  #54
02gtp4now's Avatar
very nice work looks like its coming along nice should be a great truck when done
Old Aug 16, 2007 | 08:14 PM
  #55
zz4bronco's Avatar
Great Looking Truck.i Have 72 With 5.3 Runs Awesome!!!what Kind Of Gages
And Console??zz4bronco@yahoo.com
Old Aug 16, 2007 | 09:53 PM
  #56
autometer check out pg 2
Old Aug 16, 2007 | 10:11 PM
  #57
Ackattack1's Avatar
I'm having desa vu.....
I've read all 11 pages of the build on the truck board, keep up the good work!
Old Aug 18, 2007 | 08:23 PM
  #58
got the cab back on the frame.... the front springs, drop spindles, drilled and slotted rotors are installed... and started to gut the interior.. removed the seats, gas tank, juit padding, and carpet..... laid down the dynomat extream sound deadener/ insolater.... and yes that is a couch and entertainment center in my front yard:hm:
Old Aug 18, 2007 | 08:24 PM
  #59
Old Aug 18, 2007 | 09:32 PM
  #60
Nimitz87's Avatar
amazing thread and killer build keep it up!
Chad
