3.8 to ls1 will standard trans bolt up?
Old Aug 18, 2007 | 09:28 PM
mynewformula's Avatar
Default 3.8 to ls1 will standard trans bolt up?
i bought a 00 firebird v6 and a 98 camaro ls1 and i want to put the motor out of the wrecked camaro in the fire bird . the camaro has an auto trans but i would like to bolt it up to the stand trans in the firebird. is it possible? HELP!
Old Aug 18, 2007 | 09:56 PM
89 formula350's Avatar
no differant bellhousing and input shaft length for starts
Old Aug 18, 2007 | 10:36 PM
so even if i change the bellhousing it wouldnt work?
Old Aug 19, 2007 | 01:48 AM
9540x's Avatar
Is it possible? yes. And, from what I udnerstand, fairly simple. You'll need the following for most of the conversion
bell housing, ls1 wiring harness and pcm, trans cross member, motormounts, input shaft, drive shaft and alot of other stuff I can't think of right now. Do a search, this has been done hundreds of times. If you have a more specific question, go ahead and ask...
Old Aug 19, 2007 | 11:20 AM
95GreenZ28's Avatar
9540 he is talking about using a 3.8 tranny on a ls1. Not putting the ls1 into the car. No that tranny will not work and it wouldnt handle the ls1 power even if you were to find a way to bolt it up
Old Aug 19, 2007 | 04:16 PM
9540x's Avatar
oh, my fault. I misread the post the first time.
That being said, no, the v6 tranny will be destroyed by the LS1 power. The end.
Old Aug 19, 2007 | 05:02 PM
socal's Avatar
the 3.8 is a 60 degree and an ls needs a 90 degree pattern so no its not worth it. If they were both auto then all you would do is change the bell housing
Old Aug 20, 2007 | 10:54 PM
Bird_Of_Prey's Avatar
The 3.8 is a 90 degree engine. The 3.4 is a 60 degree.
Old Aug 20, 2007 | 11:27 PM
G-Body's Avatar
sawzall wielding director
The 3.8L is a 90 deg, but it has a 60 degree bellhousing pattern on the mid 90`s and newer engines.
