A few pics of my Fox/LS1 build
#41
I thought I would give ya'll an update and post a few more pics.
I ended up making a trans. cross member out of some 1 1/2" x 1 1/2" square tubing and a couple pieces of 4" square tubing. I did use the factory f-body trany mount too. I also pulled the motor and trans back out to change the quick disconnect out on the slave cylinder. I used the Russell fittings that were mentioned in the sticky. I can't remember the number right off hand, but will look it up if need be. I also used a 26" long Russell -3 an brake line to connect the MC and the SC.
I had to shorten the MC push rod and make a mounting bracket...pretty straight forward.
I bought and installed a radiator and fan set-up out of a 2000 TA. I had to drill a hole in the core support for the drain, but that was it. I also have my fuel system installed. I used a walboro 255 in tank pump with the 99 Corvette filter just like everyone else.
Right now I'm waiting on my wiring harness from Speartech. It should be here this week , along with the PCM that I sent to Wait4me performance last Thursday.
If everything goes well I should be able to fire this thing up in a couple weeks!
![](http://img.photobucket.com/albums/v348/djquik88/100_3284.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/100_3277.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/100_3300.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/100_3306.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/mustang001-1.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/mustang003-2.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/mustang011.jpg)
![](http://img.photobucket.com/albums/v348/djquik88/IMAGE_043.jpg)
Mike
Mike
#47
LOL I knew someone would notice that. It is bolted up to the rear, but the rear end is just hanging there. I have jack stands under the torque boxes. I was installing the fuel tank at this time.
I did receive the wiring harness for Speartech today. Everything looks great !
#50
theres also 15 washers laying on the floor
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#54
Well with wiring harness back from Speartech (awsome btw) and the PCM back from Wait4me . I was able to get most of the wiring ran and the PCM mounted. I had a issue with mounting the PCM in the stock mustang location. The 98 PCM if freaking big! I ended up having to clearance the fire wall where the heater core inlet and outlet goes through because I had to shift the whole box over about 1". I started to just leave the box out, but after thinking about those cold mornings getting off of work I came to my senses.
I have also installed the flamming river steering shaft, sub frame connectors ,wired up the fuel pump and wired up the electric fans.
I loaded the car up on the roll back last Friday and took it down to the muffler shop and had the exhaust ran. I went with 3" pipe into an X pipe and turned down at the axle after the Dynomax 2 chamber mufflers.
If everything goes well, I'm going to try to fire it up this weekend....with me luck!
#56
Not yet. I will try to get some this weekend.
lol I'm not trying to make you look bad...I swear
I am only able to work on this thing on the weekends . But I try to work on it all day both days. Up until the past couple weeks it's been so freaking hot outside I didn't want to work on it. I do owe alot to my wife for not giving me a hard time for spending the last 3 months worth of weekends working on it.
Do you have any idea whan you will be able to fire yours up?
Mike
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Mike
#58
Mike
Mike
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
