04 5.3 in a 72 Chevy truck wiring help???
Old 11-06-2007, 03:25 PM
kbracing96's Avatar
Default 04 5.3 in a 72 Chevy truck wiring help???
I have a 5.3 that I'm turboing and putting into a 72 Chevy pickup http://www.performancetrucks.net/for...d.php?t=381116 and I need a little help with the wiring. I have the pin out diagram for the PCM (it is a out of a 04 Tahoe with FF) but I need to know what other wires I need to make it run. I have already removed all the wires for the sensors I didn't need in the harness. I think I need some more of the wiring diagrams so I know what wires I need to run for the data port and the fuel relay and all that external stuff and to power the PCM and stuff. Can anyone help me in wiring this up? This is he last thing I need to get this project running. My email is kybrown@gmail.com it you can send me the rest of the wiring diagrams I need thanks!
Old 11-07-2007, 10:26 AM
kbracing96's Avatar
Anyone?? I'm so close to having this running... Please?
Old 11-10-2007, 11:56 AM
kbracing96's Avatar
Well, wiring is pretty much done, but I have a question. There are 2 wires coming out of the PCM that my diagrams says are for UART Serial Data but they are different colors then the diagram says. One is yellow and comes out of blue 14 and the other is green and comes out of blue 15. The standalone flashing harness diagrams I have come across say to use pin 15 for the data connection so that what i wired to the OBDII port. Is that correct? What is the other (yellow) wire for??
Old 11-10-2007, 12:06 PM
68shortstep's Avatar
the other one is for entertainment serial data...like your radio, naviagation (if equipted), climate control, etc......
Old 11-11-2007, 05:54 PM
kbracing96's Avatar
Ok, got her running but am having a problem with the fuel pump relay. Only way it will run is if I manually ground the relay. I rechecked my wiring and it tells me that that pin 9 (grn w/white strip) on the green C2 connector is the primary fuel pump relay control. I have this wire connected to the ground on my relay, but it doesn't do anything. The PCM is throwing a fuel pump relay control code. Any Ideas here???
Old 11-11-2007, 08:32 PM
that fuel pump control is the powered sw. to the relay, not the ground sig.
Old 11-11-2007, 08:46 PM
kbracing96's Avatar
Haha, why didn't I think of that, Just went out and tested it, pulled the power wire off the relay and grounded it and walla, the damn thing worked, At least I didn't fry anything,
I just assumed it was like most everything else on these motors, where the PCM provided the ground to turn it on.
THANKS A TON 68shortstep!!
Old 11-13-2007, 09:02 AM
billyjo's Avatar
Congratulations on getting it up and running. When do we get to see the pics?
Bill
Old 11-13-2007, 11:33 AM
kbracing96's Avatar
Com on Bill you know where my build up threads are But heres a few teasers for the guys would didn't click the link in the first post!
Old 11-19-2007, 09:54 AM
JoeyGC5's Avatar
Got any pics of the motor out with the turbo manifolds on? Or just more manifold pics?
Old 11-19-2007, 10:39 AM
kbracing96's Avatar
Uses the stock manifold on the drivers side
Oh and here's a vid too
Quick Reply: 04 5.3 in a 72 Chevy truck wiring help???
