Alternator Bracket
Old Jan 28, 2008 | 10:00 AM
Buckndol's Avatar
Default Alternator Bracket
I have read lots of post and have found lots of part numbers but I still have a question. Will any of the GM mounts place a 2004 GTO alternator on the Upper Driver side? The lower mount hits my steering rack.
Old Jan 28, 2008 | 11:02 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
I have a bracket that would mount your alternator high on the passenger side.....
You would not need to mount use the other portion of the kit so I could sell it at a cheaper price.... With alterntor 420.00...
Old Jan 28, 2008 | 01:30 PM
oange ss's Avatar
without alt $ ?
Old Jan 28, 2008 | 02:00 PM
garys 68's Avatar
I ran across this. I was trying to eliminate idler and tensioner.
http://www.ls1speed.com/cont.cfm?cid=C0000801#
Old Jan 28, 2008 | 03:16 PM
LS1TECH Sponsor
I can knock off 100 for the alternator, this is not a stock f Body alternator....
Old Jan 30, 2008 | 01:07 PM
Buckndol's Avatar
Any more thoughts on this?
Old Jan 30, 2008 | 03:49 PM
DCx's Avatar
DCx
car shop, what type of alternator does your kit use? its single wire right?
i just recently bought the bracket from ls1 speed. it has no directions and i have no idea what alternator to use. i just recently got my carb ls1 running and i cant get the f body alt to charge. i tried the 470ohm resistor and it still doesnt work.
Old Jan 30, 2008 | 04:48 PM
LS1TECH Sponsor
Are you using a cs style alternator? The picture looks to me that it may be a cs style, We use this painless harness to wire up the units.
http://painlesswiring.carshopinc.com...id/43827/30707
Old Jan 31, 2008 | 12:13 AM
SMAX's Avatar
i wish someone would make a bracket to mount the alternator high on the driverside and price where the average guy could afford it. this is the last thing i left to get the el camino going and i am going to just rig something to work because (and i mean no offense to anyone) i am not going to spend $500+ just to move the alternator. is it just me or does that seem absolutely insane?
Old Jan 31, 2008 | 01:53 AM
DCx's Avatar
DCx
if my ls1 speed bracket doesnt work out i will pm you for a price on it.
carshop. will that painless harness work on my stock F body ls1 alternator? how does it hook up? if so i will order one! i found out my factory ls1 brackets will work. i just cant get it to charge.
damn, looks like i need a 30705 plug. the camaros alt is internal fan.
Old Jan 31, 2008 | 09:56 AM
LS1TECH Sponsor
I seem to see this statement alot and it kind of bugs me....The initial investment, R&D and equipment required to create such a kit is very healthy.
Not to mention having to source the parts, pay employees and keep the lights on..... For your hard earned dollar you are getting a tried and true peice that is not only built to look good but last the life of your conversion. Cosmetics are important and most homebuilt brackets just look terrible.... Why spend the money to install a high tech engine (large investment) and not make it as reliable and clean looking as possible...
Old Jan 31, 2008 | 10:04 AM
1987earthquake's Avatar
I just need a temporary home built bracket to position my alt on the top driver's side. I'm planning to later get an s&p polished setup. So mine will look good then but for now I want to be able to just let my engine run and be able to drive it to work out bugs and get body and paint and interior done. under hood beautification is least worry on my list as of now. If anyone can make me a home made braket to run my alt and water pump on a 5.3. I will be greatful. I don't want to spend a lot on somethin that will only be temporary tho. Thanks pm me if anyone can make me a bracket. thanks ahead of time.
P.S. It can be unpainted steel for all I care. I just need to be able to put a belt on my water pump and alt.
Old Jan 31, 2008 | 10:38 AM
Tom@SpeedInc's Avatar
heres our alternator relocation kit
This bracket does require the alternator option listed to use it
Old Jan 31, 2008 | 11:04 AM
I don't have any of my brackets or anything. I just want a homemade bracket to hold my alt so I can run alt wp and crank. at most all I want to have is one tensioner. I don't want to spend a lot on this because as i said it's temporary. not permanent. It will not even be on my motor for a year.. All I want is a cheap bracket don't care how it looks it can be made from flat bar for all I care. just need to be able to run my engine. nothing fancy
Old Jan 31, 2008 | 11:55 AM
LS1 SPEED's Avatar
why not buy it complete and you would have 0 issues ?
Old Jan 31, 2008 | 01:13 PM
jtune's Avatar
Here's the cheap method I used.
https://ls1tech.com/forums/showthrea...t=#post7802450 post 5
Just some flat steel and a couple small lengths of gas pipe.
I used all existing holes in the motor and head.
I welded the pipe and flat, but if it's just temporary, you may be able to get away without welding it.
For the tensioner I used the one that came with the motor. (04 gto)
If you need the length of the belt I used, let me know and I'll measure it for ya.
Old Jan 31, 2008 | 01:33 PM
Novas Forever's Avatar
I love the chatter about brackets here. I have used car Shop items and they are very good and would never say anything bad about them. It is a lot of work to get things sorted out and idiot proof as possible. We all know how stupid peple are these days . Being an old Hot-rodder I still need to do things myself to see how they will work. I am using a Classic Auto Air setup on my Nova but forget about a reasonable compressor bracket set. I WILL NOT spend $1200 on brackets to mount it!!! I have researched and studied and have brackets that will mount a Sanden compressor on my F-body LS1 high on the passenger side while being tensioned the way GM designed things. The CAD drawings are almost done and then it is to the shop to have them cut out. I don't want the billet look since that is not what I am after but they will function well and solve my problem. I hope we never stop scrounging and making stuff just because we can. It is the American way.
Old Jan 31, 2008 | 02:43 PM
DCx's Avatar
DCx
ls1 speed
i would have but the alternator is n/a on your page.
Old Jan 31, 2008 | 07:11 PM
65SSZO6's Avatar
You might contact "smokinHawk" at $70.What have you got to lose?
Originally Posted by smokinHawk
I have a new style alternator relocation bracket that mounts the alt to the passenger side head and puts the tensioner down below between the PS pump and crank.
this allows use for turbo installs were you need to free up space down below the block for manifolds or downpipes.
comes with bolts, and nuts, just need a belt.
asking $70 shipped UPS (insured & tracking) or $65 USPS (non insured)
thanks for looking.
Old Jan 31, 2008 | 07:44 PM
SMAX's Avatar
alot of us dont need a "system" just a bracket to relocate the stock fbody alternator to the top driverside. dont get me wrong cause i do like your set up, but it is just way more than i want to spend to move an alternator.
