4L60E Tail House mod?
Old Jul 10, 2003 | 11:24 AM
paulm's Avatar
Default 4L60E Tail House mod?
How could I convert my 4L60E to run the mechanical speedo in my 69 camaro? Is there a cheap way to do this?
Old Jul 10, 2003 | 12:55 PM
88ls1blazer's Avatar
Default Re: 4L60E Tail House mod?
the only way i know to do it is buy a mechanical speedo 700r4 tail shaft and got to jtr, or jags that run and buy the 6-bolt to 4 bolt adapter and you should be fine
Old Jul 10, 2003 | 02:23 PM
paulm's Avatar
Cool, I think that I can find a 700R4 tail, I just don't know where to get 4 bolt to 6 bolt adapter.
Old Jul 10, 2003 | 04:36 PM
60Chevy's Avatar
Abbott Enterprises (www.abbott-tech.com) sells a box that you can input the VSS signal and it has port to output a speedo cable drive. It uses dip switches inside so you can calibrate for gear changes and tire changes (it will make the speedo correct but not the processor). It has a small electric motor that spins the cable drive. It makes no noise I can hear. The down side is that you have to mount the box inside as it is not waterproof. Cost for the thing is around $300. The orginal application is for hour meters on modern trucks and fleet vehicles but they also know about it's use for fuel injection retrofits.
Old Jul 11, 2003 | 09:33 AM
jags that run makes the 6 bolt to 4 bolt adapter, www.jagsthatrun.com
Old Jul 13, 2003 | 03:07 PM
Rod G's Avatar
I bought the deal from street & performance and now they missed the speedometer reading by at least 10 mph. I know they would probably send me a different gear if i would pull the crossmember off and send them the gears back. I am going to change the rear end gear a little later and am going to go to a little taller rear tire. I bought a Cable-x box but haven't put it in yet. Cheaper and you can recalibrate your speedometer after any changes. To me it is the only way to go. John B has one maybe he will chime in his thoughts. Just the price of learning.
Old Feb 4, 2011 | 12:24 PM
bmf5150's Avatar
is the cable x still the way to go?
Old Feb 4, 2011 | 06:17 PM
2Aspire's Avatar
Depends on what you have and what you want..
For the cable X its nice to be able easily recalibrate if you are likely to change, for instance, gears.
Some dont like the fact that they have to deal with another box to hide.
Others "feel" the potential for failure, mechanical or electronic, is increased with a cable X
( I say "feel" because I havent seen any evidence that there are reliability issues and as such this claim is anecdotal).
For me, I had to change the tailshaft anyway because the 4L65E I purchased wouldnt work with the original tailshaft, so I decided to go with the Hybrid speed sensor/mechanical speedo drive solution.
Links are on the first post..
https://ls1tech.com/forums/conversio...l#post13649613
Old Feb 5, 2011 | 12:14 AM
builder1's Avatar
I have the cable x box and bought it from ebay less than 300 it works great and it let me keep my factory speedo. It came with all the instructions also and any questions were answered. I think that abbot sells them on ebay.
