module on negative cable
Old Feb 13, 2008 | 06:23 PM
50adrod's Avatar
Default module on negative cable
on a 2006 Tahoe engine harness there is some sort of module on the negative battery cable near the battery, is this some sort of sensing module for the ECM to control charging?
Old Feb 13, 2008 | 06:26 PM
jay_lt4's Avatar
battery run down protection, monitors amp draw and shuts down items if needed
Old Feb 13, 2008 | 06:27 PM
50adrod's Avatar
Default never mind
I found out what it does
Generator Battery Control Module
The generator battery control module is a class 2 device. It communicates with the powertrain control module (PCM), instrument panel cluster and the body control module for electrical power management (EPM) operation. It is a serviceable component that is connected to the negative battery cable at the battery. It directly controls the generator field control circuit, charge indicator control, input to the generator. It continuously monitors the generator field duty cycle signal circuit and the battery voltage. If the generator battery control module loses communication with the PCM, the default voltage will be set to 13.8 volts and the module will set U1016. If the generator battery control module loses communication with the body control module (BCM), the module will set U1064.
Old Feb 14, 2008 | 09:29 AM
philntx's Avatar
Just curious...How did you come up with your answer?
Old Feb 14, 2008 | 05:41 PM
50adrod's Avatar
GM service manual
Old Feb 24, 2008 | 08:28 AM
fastrucken's Avatar
Has anyone figured out how to bypass that module?? Im running a 03 suburban motor in my 65 chevy truck and not using the stock computer. My alt only puts out 13.8v and would like the additional 1v.. but it is a 160amp alt so would like to keep it.
Graham
Old Feb 24, 2008 | 08:55 AM
50adrod's Avatar
Graham
are you letting the computer control the charging system?
Old Oct 12, 2008 | 09:27 AM
fast400's Avatar
Default 50adrod
Did you wind up using the module? I just ordered a negative cable with the module attached for my 06 5.3 harness. The problem I'm having, is that of the eight cables, there's two cables on the plug that hook to the module, which come from the fusebox C2 connector(big rectangle with a bunch of pinks). I have no idea where to place these two: Blue--Engine on signal; Orange/blk--UART serial ckt1061.
Did you eliminate yours? If so how?
Old Oct 12, 2008 | 07:37 PM
50adrod's Avatar
I did away with it and am wiring the alt seperatly
check this out
http://www.ls1truck.com/forums/elect...amp-alt-2.html
Old Oct 18, 2008 | 08:14 AM
fast400's Avatar
I'm thinking about keeping the battery module on the Neg Batt cable. Has anyone kept it? I can't figure out the orange/blk serial data wire from the module. It shows going to the DLC, but that doesn't make sense to me. Which pin?
Old Oct 18, 2008 | 09:04 AM
50adrod's Avatar
I think you will need some of the interior wiring harness and modules to make it work.
Old Oct 18, 2008 | 01:51 PM
fast400's Avatar
Why would I need interior harness?? It's gotta be easier than that.
Old Oct 18, 2008 | 03:52 PM
fast400's Avatar
...here's why I ask...
http://64.91.234.154/coppermine/albu...k_Sep_2004.pdf
It's the first page center paragraph that's got me wondering.
Old Oct 18, 2008 | 07:26 PM
50adrod's Avatar
I guess you need to determine what system you have. I mainly work on imports and fords and you have to have the body control module in the system to provide the data for the ECM to control the charging system.
Old Oct 19, 2008 | 03:52 AM
fast400's Avatar
I've got the module that's on the negative cable (doesn't use the BCM). I like the idea of the module controlling the voltage at different stages, which is why I wanted to retain it....but it seems like it might be a pain.
