Oil Pan Dilemna
I dropped the 4.8 in my '79 Malibu today and the stock truck pan is way too low for comfort. It hangs 3+" below the crossmember. From what I've gathered, I have a few options.
1. Modified F-body pan from S&P or other vendor (about $250).
2. LH8 pan, but it is only 3/4" shorter, so I'll probably pass on this option (abount $180-250).
3. Cadillac CTS-V. Some think this will fit with no problems. No one can say for certain, so I'm scared to dump $200+ into an unknown.
4. Moroso pan. About $300 with pickup + you have to run remote filter setup, so that adds about $50-100 more.
Am I leaving anything out? Has anybody run the CTS-V pan in an application that would let me know if it would work in my application?
Here's a couple shots of the truck pan in my Malibu:
I don't have the equipment to weld aluminum. Although, I could probably find someone locally to do it for me. I'd prefer to go with a known working application.
http://moroso.carshopinc.com/product...id/90960/20140
We also have this one, it does have the fliter housing in the stock like location.
https://ls1tech.com/forums/showthread.php?t=866537
Mind is just a bit more then 1"...
This is using 1/4" plates, tall and narrow engine mounts. short and wide frame mounts.
If you need more photo and if I have them.. let me know..
http://www.fquick.com/garages/viewga...ewimg&id=17178
http://www.fquick.com/garages/viewga...id=3043&page=3
Malibu Racing: it looks like your mounts position the engine a little higher in the frame, so the CTSv pan may be an option. On my car the f-body pan is about 5/16 to 1/2 above the bottom of the crossmember. The tight spot will be on the sides of the CTSv pan where it slopes down towards the sump.
