TH 350-400 users
Old Jul 16, 2003 | 10:02 PM
Lesrace82's Avatar
Default TH 350-400 users
what did you use for a convertor? did you use the convertors for the regular small block or big block chevy? did it bolt up to the LS1 flywheel or did you have to drill new holes?
Thanks
Bill
Old Jul 18, 2003 | 11:07 AM
GREGGO's Avatar
Moderator
Default Re: TH 350-400 users
I agree.....Kinda stupid looking too.
Old Jul 20, 2003 | 09:00 PM
Heimbig's Avatar
Actually, I believe GM makes a special automatic flywheel just for such a connection.
Old Jul 20, 2003 | 09:51 PM
LS-1st-Gen's Avatar
interesting
Old Jul 21, 2003 | 02:28 PM
C4VetteLS1's Avatar
i used stock 98 flexplate, oblong'ed the hole slightly, to a normal 9" th350/400 dual bolt pattern converter. Then i used washers to space between the flexplate and the converter, to keep it from pulling the converter out of the tranny..
Old Jul 21, 2003 | 02:48 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
GM makes the correct crank flange spacer and longer bolts to do the job right.
Using washers between the torque converter and flexplate causes you to loose your centering register between the crankshaft and the torque converter, which can lead to vibration and trouble.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jul 28, 2003 | 06:31 PM
C4VetteLS1's Avatar
whats the part # to get this spacer?
Old Aug 25, 2003 | 03:26 PM
blkmgc1's Avatar
you sound like you know what your talking about.can i ask a question.i can't seem to find aan answer on this whole web site.i need a total swap for a t56 to a 350 turbo.what exactly would that entail in a 2000 ss camaro.i need to know all the parts and i did'nt know about the fllywheel thing so i got a least one answer thanks.
