VSS for a Muncie?
Old Feb 28, 2008 | 09:14 AM
gremjimi70's Avatar
Default VSS for a Muncie?
Anyone know where I can find a speed sensor that will work in a Munice 4-speed? I've been told their out there. Is that you guys are getting around usieng the early model transmissions with these motors or is there some other way?
Old Feb 28, 2008 | 04:41 PM
Novas Forever's Avatar
I have done it. I think the process is in the STICKY section.
Old Feb 28, 2008 | 04:42 PM
84vette's Avatar
im not sure what the rules are for posting/answering questions, but i was using a vss generator in my muncie to send a signal to a 200mph electric autometer guage and it worked great. I took it off my muncie since im in the process of doing an ls1 swap. i could sell it to you i guess. not sure how that works on here , i guess just message me or something and we can set something up. thanks
Old Feb 28, 2008 | 05:46 PM
Project GatTagO's Avatar
You need a VDO or similar sender in the tranny, then use a Dakota Digital speedo converter to convert the hall effect signal to a square wave.
Andrew
Old Feb 28, 2008 | 08:32 PM
classic gary's Avatar
i think "Jags That Run" has the tail housing or can tell you were to get one.........
Old Feb 29, 2008 | 07:25 AM
LS1MCSS's Avatar
www.magsensors.com p/n 413022-60 is for a 4 pulse per rev, square wave vss. No signal convertor needed.
Old Feb 29, 2008 | 07:58 AM
Awesome! They even have a dual output, so I can feed my autometer speedo and the ECU.
Andrew
Old Feb 29, 2008 | 08:07 AM
rao's Avatar
rao
That is very cool.
Old Feb 29, 2008 | 08:10 PM
LS1MCSS's Avatar
I don't know who will do the programmng for you, but you might need to know, EFI Live only goes down to 10 ppr in the VSS settings. HP Tuners goes to 0.
