s-10 v8 conversion
Old Apr 13, 2008 | 10:43 PM
  #41
098z28's Avatar
btw i beleive the chain to get is a ls2 stocker
Old Apr 14, 2008 | 05:57 PM
  #42
sparkwirez06's Avatar
Default pushrods
you will need the longer 7.4 pushrods to work with the z06 cam.
Originally Posted by Xtremedueces
So I have been working hard on this swap and here is an update. Any advice or recommendations at this point would be greatly appreciated. I bought swap headers and sent them off to a friend for ceramic coating, not bad for $100 for the pair.. Decided on the ls6 stock intake, bought a nice ported and polished tb off ebay. Bought z06 cam off ebay and I am ordering valve springs ( deffinately looking for a recommendation on these, and I am not working on the largest budget )
Using stock pushrods and lifters. Bought 08 h3 pan ( GM took forever to get it to me though) notched frame for a/c. I am in the process of porting heads.
Still not sure about injectors, anyone think the stock truck injectors will keep up based on these mods? Or should I do it up ***** with some bigger ones?
Also thinking about gear to gear set up or double roller. My stocker looked a little out of spec ( visually but maybe it was really fine but why not upgrade now then later. Ill try to post some pic soon the truck it in nice condition with 22's and all shaven paint job.
Old Apr 14, 2008 | 09:40 PM
  #43
Xtremedueces's Avatar
You sure about this, anyone else know about this?
Old Apr 15, 2008 | 02:23 PM
  #44
SUPERWAKE502's Avatar
From what I've have read the 7.4's are fine. Now I am running a 598 lift and after I checked it, my 7.4 will be the right length. So I plan on ordering some chromoly ones before I crank it.
Old Apr 16, 2008 | 08:36 PM
  #45
fast_s10's Avatar
That ZO6 cam part # is GM PART # 12565308 its around 245.00 new from GM
Old Apr 18, 2008 | 11:45 PM
  #46
Where are those numbers found ( on the shaft or the end of it) cause I dont see them on my cam and I am beginning to think I got scammed on ebay
Old Apr 19, 2008 | 05:01 PM
  #47
It's on the end of the cam.
