My ls1 chevelle build
So far I've ordered:
LS2 timing chain
Comp custom grind cam (similar to a Thunder Racing TR230/224 reverse split)
stock MAF
ported LS6 oil pump
.080 wall Comp pushrods
Comp 918 valve springs
Still need: headers, rod bolts, harness, ECM, air filter, make some custom engine mounts, LS6 intake, fuel pump, throttle cable, and plenty of time to massage this thing into the hole with the stock oil pan and acc. drive system.
Should be pretty fun when I'm done and still be 100% daily driveable...prolly even increase my fuel mileage quite a bit so long as my foot doesn't stay planted to the floorboard
Updates to come. Cam is going in Easter weekend. Also might massage the head ports, and will polish and port the throttle body.
:shiftingfun:
With 4.11 gear and the T56.. I get 23+ on the freeway (70-80mph).. not great.. but when you consider the gears.. it great for me...! LOL
Harness is 99% done.
Stock cam had a failure on 2 lobes so I need lifters and then the motor is going back together and into the car.
Hopefully the car will be close to running by the end of next weekend.
99% done ? how hard was it ?
Been workin so much ive been thinking sending it out may be easier but i hate other people workin on my ****! lol
Looks like it will be a sweet swap!
Youre already getting over 20 mpgh on the freeway! What size are your shoes?(feather foot! ...lol!)
I'm actually wondering if the harness is done right it was so easy...I didn't strip it though. I just unplugged the crap I don't need from the ECM pin out per the sticky and cut the wires loose from the 3 F body plugs I need and soldered new wire leads onto them that will go to an underhood fuseblock. I went to the salvage yard and got a OBII port for $4 and soldered it onto the harness. All in all it took me prolly 3 hours using nothing but the info from the stickies here. It only took that long because I was double checking all the info and taking my time.
Yeah I got 23 mpg from Ft Smith, AR where I filled up to my house in Valliant, OK. 30 minutes of that drive is at 45-50 mph through the Ouachita mountains too.
Street Avenger 670 with larger front jets, mild 320 hp 350, 700r4 with lockup, and 3.42 12 bolt out back.
City mileage blows though...from my house to work I average about 11mpg over the week. This is 90% babied at 45mph and 10% romping around for fun.
Im glad to hear that it wasnt a nightmare!
Im definately gonna go ahead and lock myself in the garage with my laptop and do it myself! Thank god for everyone on this site!
Cant wait to see more pics!
And damn it must be the 700r4! my 72 camaro gets like 12 on the freeway (3:42s th350, mild 355)
and nothin round town! Cant wait for fuel injection! lol and a well designed engine (by present technology I love sbc any gen!) ..
with brand new comp 918 springs the seat pressure on several is 50-75 instead of into the 100s as it should be
it never stops around here...I should have sent my 5.3 truck heads to have better valves put in instead
my home ported throttle body, needs more work but I'll get to it.
I am in the process of pulling my harness apart to get all of those unused wires out of it. I don't want all of those wires in the harness nor the connectors on the other end. I will probably have more than 3 hours in it though.
There are older pics on my cardomain, but my roof had a clearcoat failure so it peeled and rusted, I'm about to sand it down and shoot the whole roof in black epoxy primer to mimick a vinyl top until I can afford to have the car repainted.
I'm gonna try to get some videos soon of the exhaust idling, cruising, and WOT. It's actually very tame sounding...very unsuspecting. *sneaky eyes*
