LS1 In An FFR Roadster
Old Sep 8, 2008 | 10:19 PM
  #101
magic's Avatar
^^ I dont understand by that last pic above there how you are planning to regulate the fuel pressure??
Have the pump feed the rail(s) directly, then FROM the rails into the regulator...the bottom port on that Aeromotive regulator is the return part which goes back into the tank....
Old Sep 8, 2008 | 11:44 PM
  #102
tails8's Avatar
^^ Yes the bottom port on the FPR will be the return line going back to the tank. Looking directly at the FPR in the last pic the line going into the left side is the feed from the tank, the line going out the rightside of the FPR is feeding the rails. I still have to cap one side of the rails so fuel doesn't spew out all over the place..
Tails
Old Sep 9, 2008 | 10:29 AM
  #103
magic's Avatar
Tails
I think it would be better if you fed the rails directly from the tank, and the regulator after the rails are fed, instead of regulating the fuel before they go into the rails....<---Going by what you said above ^^ it looks like you are going to regulate the fuel before they go into the rails??
Very Nice build up by the way!!
Old Sep 9, 2008 | 08:21 PM
  #104
tails8's Avatar
When I was putting the system together I was told to route the fuel that way. Why the other way? Or will I run into issues doing it like this?
Thanks for noticing BTW...
Tails
Old Sep 9, 2008 | 08:49 PM
  #105
sciff5's Avatar
Just curious Why?
I would rather have all my fuel stuff out back
Old Sep 9, 2008 | 09:03 PM
  #106
magic's Avatar
Originally Posted by sciff5
Just curious Why?
They I mentioned, really is the proper way to do it in a Fuel Injected Application! will keep the rails pressurized and filled (volume) at the set PSI at all times at all RPMs (as long as the pump keeps up, ie. no voltage drop and pumps less volume)...and the injectors will fire out the fuel as needed as the RPMs rise....
If you regulate the fuel pressure before the rails: bascially you are just regulating line pressure and NOT Rail pressure which is really needed in an EFI app. Also, When the fuel injectors open, they will drain the rails before the regulator allows more fuel to fill up the rails...you WILL run out of fuel in an instant! The car wont run well if at all!
Now if it was a carburated application, then the way Tails already had it setup, regulating the fuel pressure before it goes into the carb, is the "proper" way...
Just my cpl cents on the matter.
Old Sep 9, 2008 | 09:09 PM
  #107
sciff5's Avatar
If you regulate the fuel pressure before the rails: bascially you are just regulating line pressure and NOT Rail pressure which is really needed in an EFI app. Also, When the fuel injectors open, they will drain the rails before the regulator allows more fuel to fill up the rails...and in doing so especially at WOT, you WILL run out of fuel in an instant = CATASTROPHE!
well ****.. I wonder if my fuel setup is correct then I have stock rails/stock FPR with a corvette filter and return.. although the return is before the fuel rail (in the back of the car).
Old Sep 9, 2008 | 09:21 PM
  #108
magic's Avatar
See now, I should have mentioned the two different types of fuel system setups....
Return and Returnless....Im going to assume you already know about these two types? But Im just going to re-iterate it and going to explain it the way it was explained to me....
The Return is what it is...has a return line, with a fuel pressure regulator regulating the fuel pressure (a set pressure at all rpms), and the excess is returned back into the tank....because the pump, pumps out a specific amount based on time at all rpms... (litres per hour, gallons per hour)
The returnless, is just that...has no return line....there is a fuel rail pressure sensor (on the fuel rail) that does as it says... senses fuel rail pressure, along in conjuction with rpm...if the rpm rises, the fuel rail pressure sensor, tells the computer to tell the fuel pump to pump more flow....so basically this system sends fuel to the rail as its required....
What your system has, is a returnless I believe, on the Corvettes...Im more familiar with the Mustangs, but just about any EFI system is all inter-related somehow.
However, Im curious to learn exactly how this setup works on the Vettes?? Its almost like its an inbetween of those two types of fuel systems?
Old Sep 9, 2008 | 09:48 PM
  #109
sciff5's Avatar
I actually have an ls1 from an 00 trans am ws6 in an rx7 (it is returnless) I have a fuel cell out back with a pre filter to an inline walbro 255 to the corvette filter (which also has the return which loops right back to the cell) out to the hard line and to the fuel rail.. Hope this works
Old Sep 10, 2008 | 01:54 AM
  #110
tails8's Avatar
The way it was explained to me was with the external walbro I will probably run into and over pressure issue if I ran it directly to the rails with the FPR after. This way it keeps the pressure under control coming from the pump into the rails.
Interesting discussion non the less.. I might change it up just to see what happens..
Tails
Old Sep 17, 2008 | 04:04 PM
  #111
tails8's Avatar
Here's some pics from last weekend. Decided to do a trial fit of the body so I could see what I'm going to need to move. Looks like all I gotta do is move the brake/clutch fluid reservoirs down or out a little. Like I said rough fit to see what I got to work with. Enjoy...
Tails
Old Sep 17, 2008 | 04:41 PM
  #112
vapoppa's Avatar
WOW---- thanks--- mase
Old Sep 17, 2008 | 10:31 PM
  #113
magic's Avatar
Looks good! What color are you going to paint it?
Old Sep 17, 2008 | 11:41 PM
  #114
tails8's Avatar
Still thinking about the color. Haven't made a firm decision... Yet..
Tails
Old Oct 14, 2008 | 02:23 PM
  #115
tails8's Avatar
Damn been almost a month since an update. Nothing major going on right now. Working on lots of little stuff, not really post worthy. Got the radiator, fan, and shroud done this past weekend. Will work on getting the side pipes mounted and the body back on again to check alignment. It's to the point now that all the mojor stuff is installed. Just have all the little nit picky stuff to take care of so don't worry I haven't stopped. Here's some pics..
Tails
Old Nov 24, 2008 | 02:26 PM
  #116
tails8's Avatar
Started the wiring this past weekend. Got the engine harness and the chassis harness routed and layed out. We'll see how much I get done next weekend with it being Thanksgiving and all. Either way gotta start on the gauges, fuel pump, relays, etc... Sorry about the lack of updates just not as many major things done now. It's more little stuff, not really pic worthy. However still moving ahead as much as I can. Next major goal is to get this thing fired up. Getting close..
Tails
Old Nov 24, 2008 | 03:34 PM
  #117
dimeraider's Avatar
Are you going to be running a turbo or did you just have header clearance issues and decided to run them forwards?
Old Nov 24, 2008 | 03:54 PM
  #118
tails8's Avatar
Had to flip em. The exhaust pipes run infront of the footboxes and out and down the side of the car. Similar to this pic..
Tails
Old Nov 24, 2008 | 05:35 PM
  #119
sciff5's Avatar
Did you think of trying the 5.0 headers that most people use. Basically you can just hack off the flange from the 5.0 header round out the primaries and weld the Ls1 flange right onto it. Its really easy.
The external dimensions of the ls1 and the 5.0 should be similar but I'm not sure.
Old Nov 24, 2008 | 07:43 PM
  #120
tails8's Avatar
At that time I didn't really know for sure if the dimensions were the same. I had already come across these headers so I went that route for now..
Tails
