RX7/forged 370/TC78
#102
update, upgraded to a new GTS 78 turbo from the TC78
it was a step from a 68mm turbine to a 75mm turbine to give me some headroom
the compressor cover was a fair bit larger but just barely fit
Got the IC plumbing all done, really like how it turned out.
3" aluminum, only two couplers
#106
yeah i will dig back and get you some
got it all together and running
all i can say is that thing is going to be nasty now with that converter and transbrake
converter is tight but i can still light up the new turbo to full boost like nothing with the brake
muffler isn't hooked up yet, so that is why it is so loud
http://www.youtube.com/watch?v=q_7bD8ORT_w
#107
got the fans done
didn't quite have the depth to fit a taurus fan so i got a dual setup off of summit
worked out great, my core size is 24x16 and these where 23.5x16 with a little trimming on top
anyway, made this little deal and then it bolted to the radiator just right
#108
got some pics of the cage, I guess i have never done any cage work ever, but i like the way this turned out
I can't believe what a cage will do to the chassis, I have always heard it stiffens them up but i can't believe how much
i can jack on one front corner now and three corners come up very easily, never was like that before
DOM material, SW kit that got worked over quite a bit
#110
thanks!
made a super special bracket for the BC, haha
did cause I can't get to it like before with the compressor clocked like this now
Hallman must have a ridiculous anodizing system..... i welded it on there and it didn't discolor anywhere, usually anodizing has always discolored in the near area of welding for me
#112
#113
ok have a few projects because it is supposed to snow again
hood dampers
add another muffler
sump the tank
add an electric cutout in the front fender
First i bought the cheap ebay set of dampers....... didn't like how they worked; they didn't open the hood nearly enough for my liking, and they made the hood bow at the rear because of where the gas spring pressure was being applied
So went to my hook up and John Deere and got a couple the length i wanted with the force i wanted
i changed where the little brackets mounted and TIG'd them to the hood arm so they didn't move all gay like
turned out great, can't believe i finally got it done........ i got rid of the stops on the hinges so that it opens WAY up now
next is a tank sump
I don't know who undercoated this car but it is ridiculous, stuff is so thick it makes a mess taking it off anywhere
shot some bedliner stuff on there when i was done, not done with redoing the pump mounting and plumbing
next is a muffler, adding another 14" magnaflow upstream of my current one, doing this to make it even more quiet
I just like going from sounding like nothing to pist off when the gates open
and last is a cutout right off the turbo to the front fender..... working on that
hood dampers
add another muffler
sump the tank
next is a tank sump
#116
did some more today
here is the start to the cutout
I plan to go from that Vband the rest of the way down to the cutout and out the fender with aluminum
will 16 gauge be fine or will i need something like 11? anyone?
and then did the pump mount, you can see in the one pic where the second muffler went
#119
thanks guys
ok well my cutout still hasn't got here but called DMH and they said it will be here tuesday
so i decided to finish it anyway and then splice the cutout in when it gets here
turned out nice, car sounds like it means business for sure! love how i have the idle now too
turned to lock
and a cool little vid
turbo lsx rx7 now with DMH cutout to the front fender
turned to lock
