Engine rpm drops
Old Jun 14, 2008 | 01:03 PM
Ram Air IV's Avatar
Default Engine rpm drops
Hi !
I have now completed my engine swap and everything works fine except one crucial thing. When I hit the trottle and release it immediately the rpm drops significant and if I do this with the transmisson in drive the engine stops. I know that the engine worked fine before the swap. I wonder if I have missed something. I have changed from cast exhaust manifold to headers, should I tune the PCM? I dont have a scanner tool yet but the MIL does not lit. Anyone have a clue what is wrong ? / Magnus
Old Jun 14, 2008 | 01:17 PM
bczee's Avatar
Have you checked for Vacuum leaks or Fuel Pressure ?
Old Jun 15, 2008 | 03:49 AM
Ram Air IV's Avatar
Default Engine will not run when warm
No, I will check that to day. The engine runs fine when it is cold, the problem occurs when it reach the working temperature (185-190 degree F). Is the engine sensitive to minor changes such as delete of catalysators or adding headers, since this is what I have done. M
Old Jun 15, 2008 | 04:43 AM
Joshiedoom's Avatar
Tps ?
Old Jun 15, 2008 | 04:49 AM
OldSchoolFormula's Avatar
Originally Posted by Ram Air IV
Hi !
Drive it more. Whenever I let the PCM reset on my car, the PCM had to relearn how to idle and recover. I didn't have any tune for the cats or headers, either.
Old Jun 15, 2008 | 11:49 AM
Ram Air IV's Avatar
Hhmm ! What is TPS ?
I will try to drive it more and see if PCM recalibrates.
When I release the trottle the engine rpm drops to about 900 rpm and after less than a second the rpm drops to 200-300 rpm and if I am lucky the engine does not stop. Then after 1-3 seconds the rpm goes back to 800 rpm. It is not a problem to rev it up to like 4000 rpm. M
Old Jun 15, 2008 | 11:52 AM
Ram Air IV's Avatar
Sorry ! Trottle Postion Sensor. M
Old Jun 15, 2008 | 03:18 PM
Ram Air IV's Avatar
I have now tried to find if I lose vacuum somewhere. I found that the MAP-sensor in the back of the intake is little loose ! should it be like this ? It is a LS1 (Corvette) intake. M
Old Jun 15, 2008 | 10:28 PM
Joshiedoom's Avatar
It could be the problem, but the TPS went out on my ls1 and it when it shifted to OD at very low speed it almost died. Same for comming to a stop. RPMs would go down to like 250.
Old Jun 16, 2008 | 01:37 AM
leonpiper69's Avatar
also, where is your maf mounted? if it is too close to the throttle body it can super sensitive.
just learned this the other day. my friend an i did an ls swap in his s-10 and to get it running (temporary) we just used a short (like 2 inch) connector to connect the maf to the throttle body and once it warmed up (entered closed loop) if you put it in gear (or came to a stop, we took it around the block like that) it would just about die. connected the maf like 10 inches away and solved the problem.
Old Jun 16, 2008 | 03:54 AM
Ram Air IV's Avatar
I have mounted the MAF on a 90 degree elbow, so it is like 7-8 inches from the trottle. Do you think this is ok ? M
