View Poll Results: Would you like our own section
Yes
252
89.05%
No
10
3.53%
Don't care
21
7.42%
Voters: 283. You may not vote on this poll
Carb LSX guys step in please...
Old Apr 21, 2009 | 02:58 PM
  #221
95greenmaro's Avatar
the guy said that the motor and tranny were good in it. the intake is unbolted on the car, but it will be out and for sale soon. it has a 700r4 in it. would the tranny be worth keeping or should it go as a package deal and go with a th350?
the car will not see any street time
Old Apr 21, 2009 | 04:04 PM
  #222
topher455's Avatar
Originally Posted by NemeSS
yes, the blow thru/carb. info over there is second to none.
all the stang guys over there are cool and have some serious carb.knowledge
I have talked with you a few times in the chevy section. Same screen name over there.
Old Apr 21, 2009 | 04:11 PM
  #223
NemeSS's Avatar
if youre serious about, carb. u will not need, the intake.
staying n/a with a mild cam like the ls6 will make some nice power.
spend your $ on the conversion, make sure u get the wp, coil packs, and anything else that comes with it, if the trans cost more than 100$. not worth it. unless u plan on going with efi. trans is pcm controlled.
im going with th350. and sbc tq converter. im working on a budget setup
for 3rd gen swappers for acc..
pm if would like more info.
edit: if it comes with a 700r4, it has been swapped to work with lsx.
all auto lsx came with 4l60e type trans.
Old Apr 21, 2009 | 04:12 PM
  #224
NemeSS's Avatar
yes, i know i was keeping tabs on your build up.
Old Apr 21, 2009 | 04:33 PM
  #225
the car still has the 2.8l in it with the 700r4. i am leaning towards running a th350. I am on a tight budget
Old Apr 21, 2009 | 04:34 PM
  #226
what part of houston are you in?
Old Apr 21, 2009 | 06:17 PM
  #227
dkbykesdk's Avatar
adapter fittings are available that allow the use of conventional sbc type sensors for water temp and oil psi. they screw in place of ls1 sensor and the a sbc type sensor can be used. for autometer, stock mech. gages and such
right but there is so many different fittings was jsut wonderinf if any one knew exactly which one to get
Old Apr 21, 2009 | 07:09 PM
  #228
topher455's Avatar
Call autometer they will tell you the pn for both. Thats what I did but I cant remember the pn its been a while
Old Apr 21, 2009 | 07:37 PM
  #229
Shawn MacAnanny's Avatar
Autometer water temp sensor adapter is 2277 you can order it from Autozone, theres a sponsor here that sells a kit with that and the oil pressure sensor for like half the cost. I think its like $7 for just that one adapter though.
Old Apr 22, 2009 | 09:21 AM
  #230
killah1's Avatar
hey whats up guys well im in the middle of doint my carb ls1 in my 73 short box
ok if somebody can send me a link to were i can buy the mani an the msd 6010 box i have seen a kit in summit racing but it is not the msd box
please help me out tanks
ps this is a good tread
Old Apr 22, 2009 | 09:34 AM
  #231
topher455's Avatar
http://www.sdparts.com/product/88958...arburetor.aspx
http://www.sdparts.com/product/MSD60...edEngines.aspx
Took about 30 sec. Try to do some leg work first or people will get frustrated w/you. Welcome to the site BTW.
Old Apr 22, 2009 | 12:01 PM
  #232
supreme84's Avatar
the 700r4 from the 2.8 will not fit, much smaller bellhousing
Old Apr 22, 2009 | 12:13 PM
  #233
NemeSS's Avatar
i am also using a th350 with sbc 10in tq converter, im using hughes flexplate which is a sbc flexplate with ls crank flange bolt pattern. still need to use 6.0 spacer.
u can however use a 6.0 flexplate with spacer and sbc 10in. tq converter. u will also need the b&m th350 swap for 3rd gen. allows use of stock tq arm, need new driveshaft. but prolly cheeper for u to find tpi 700r4 and use all the hardware, ds, tq arm, etc. will still need flexplate conversion though.
Old Apr 22, 2009 | 04:04 PM
  #234
i wasn't going to use the 700r4, it will be going for sale with the 2.8l
Old Apr 22, 2009 | 04:05 PM
  #235
it is going to be a track car only. th350 is the way that i will be going. How much power can you get out of the 5.3's?
Old Apr 22, 2009 | 07:25 PM
  #236
topher455's Avatar
N/A or forced induction?
Old Apr 23, 2009 | 02:35 PM
  #237
NemeSS's Avatar
275rwhp thru th350 is possible.
go with manual steering
Old Apr 23, 2009 | 02:55 PM
  #238
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'll put my name in here as well. I've done the swap with my TA
Old Apr 27, 2009 | 12:47 PM
  #239
NemeSS's Avatar
pm sent
Old Apr 27, 2009 | 03:02 PM
  #240
i would like to do a single or twin turbo set up on it
will be running 1/8 mile only
would like to see low 6's high 5' if that is possible
