1986 el camino with 6.0 need trans help!!
Old 07-29-2008, 06:21 PM
nonamebbq's Avatar
Default 1986 el camino with 6.0 need trans help!!
I have a 86 camino. I have a friend who crashed his truck, I think its an 04/05
model. Its a chevy 2500HD with the 6.0 . Will any 97/02 T/A or camaro trans bolt up to this motor with no problems (T-56) I can get this motor for $$1,200.00 But don't want it if I can't put a 6 speed behind it. If It will work, I will post pic's this weekend of the conversion. Thanks all.
Old 07-29-2008, 07:14 PM
LS1MCSS's Avatar
A 98-02 T56 might bolt up to it, but a 97 will be an LT1 T56 and it's different.
Old 07-30-2008, 07:45 AM
nonamebbq's Avatar
Your right, my bad, its 98/02 transmissions.. I know the only thing i would
need to replace would be the flywheel. I don't see why it would not work if the LSX are supposed to be all the same!. I want to be double sure
Old 07-30-2008, 08:17 AM
nonamebbq's Avatar
I been doing some reading on here and some folks say
that some 6.0 have different cranks (longer). How do you
know what year models to stay away from?? This is the
problem I don't want to run into. THANKS
Old 07-30-2008, 08:28 AM
SMAX's Avatar
The early 6.0's had the different crank. You will be fine with that particular engine.
Old 07-30-2008, 09:07 AM
nonamebbq's Avatar
Do you know up to what year??. I am going to call him
today to make sure of the year. I do know for sure its an 04/05 model.
and whats the difference from LQ4 and LQ9??.. THANKS
Old 07-30-2008, 09:42 AM
SMAX's Avatar
I think it was the 99 model. LQ9 has a little more compression. Like I said you will be fine with that engine 04 or 05.
Old 07-30-2008, 10:23 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
The lt1 t56 can be used but will require changing a few front end parts on the trans..... the 6.0 sounds like a good buy.....it will make a fun toy!
Carshopinc.com
Old 07-31-2008, 12:41 AM
sawzall wielding director
G-Body's Avatar
The 99 and 2000 4.8 and 6.0L`s had longer cranks. The 6.0`s also had steel heads on those years
Quick Reply: 1986 el camino with 6.0 need trans help!!
