ls1 fuel tank ideas
what about just a stock camaro tank? i know it would work but are there any better ideas? i saw the corvette tank and i would use it if it wernt a two piece. i was thinking if i could make a toolbox into a gas tank some how. i've seen diesel slip tank's that are over 100L. what would be a good fuel pump for that? do i need a regulator? or does the ls1 have one built in? thanks guys, i know i could look for hours on here and find answers but this takes less time. theres alot of usless threads
I think it's going to be less headache to either get an aftermarket tank for your truck or use the stock tank and add either an in tank pump or a pump on the framerail.
I dont think on your truck where there is plenty of option for the stock tank or aftermarket tank, trying to get a different vehicles tank to work is a worthwhile option.
AND, if you did search, and then ask, people will be more open to helping. Plus, you can see what problems they may have had, and will know what to do if you hit the same snag, AND you can even get other ideas too!
Here is a few I found from a quick search:
https://ls1tech.com/forums/showthrea...kup+chevy+tank
https://ls1tech.com/forums/showthrea...light=70+truck
Oh yeah, how could I forget this one..... sorry.
http://67-72chevytrucks.com/vboard/s...d.php?t=233302
Here is a good L O N G post about a fuel system.
https://ls1tech.com/forums/showpost....&postcount=188
Here is the beginning of some good reading material.
https://ls1tech.com/forums/conversions-swaps/370781-my-ls1-t56-swap-into-68-chevy-c-10-stepside.html
