msd 6010 timing accuracy
got my TDC marked now, gonna put the dialback timing light on it today, compare with the laptop
there was one guy running e85, had 29 degs total, but he was running a procharger-what octane is e85, high 90's?
they sell it around here, but no place convient
if i reved it up a bit, it would be steady-anyway, appears the msd box is accurate-i am using a serial port cable to a usb cable adapter, so that was a concern-tomorrow is dyno day, so i know one thing will be reading right, lol
i gotta get some e85, i think the carb needs mod'ed, right-to flow a lot of fuel
That is because the MSD box uses spark stabilizer at idle. Makes the engine idle smoother. That is why you see the timing moving.
40 degrees seems like way to much, especially around torque peak. Better be carefull with that.
