LQ4 into a 3rd Gen/1972 Nova
Here's a 45* fitting, would require some P clamp or rerouting to stand it off from the subframe sheetmetal....
Here's a 90* fitting, would require some P clamp or rerouting to stand it off from the engine mount....
In other news my replacement shipment for the missing replacement valve shipped yesterday.. hopefully I can get the heads assembled this week and on the short block this weekend, and then mate the flywheel/clutch/trans and put all that back in the car!
Overall the clearances for the pan are surprisingly large. I think as long as someone isn't using the "oem" motor mount pedestals like I previously was (which had a large overhang on the back of the subframe cross-member) and someone uses forward-mounting motor mounts & adapter plates, then the turbo drain line routing shown in my pics shouldn't be an issue.
Last night I made the passenger side block-mounted adapter plate pushing the passenger engine mount forward 1.75".. but I haven't started modifying the subframe mount pedestal yet. Before I do that work... this has me thinking about the idea of remaking the driver side motor mount pedestal out of 100% fabricated thick-wall tube for the horizontal bolt, and reinforced rectangular tube as the vertical support, to open up room on the inboard side of the pedestal (between it an block) as well as on the outboard side (near downpipe).
Only unknown headache would be.. how to attach hard line to AN 90* fitting? Only options I can think of are:
1) find an industrial shop to flare the 5/8" tube to a 37* JIC flare
2) buy a -10AN steel male bung and weld it to the end of a stainless tube, use a 90* female -10AN to 1/2" NPT
Red is the 100%-fabricated motor mount pedestal, blue is a 90* -10AN male to 1/2" NPT, purple is 5/8" tube with bend and flared for a -10AN tube nut....
I'll test fit this weekend, and if it all fits well, will reinforce with gussets and stuff. My thinking is, it's new steel, thicker than original, and will allow plentiful room for hard/soft line routing... so no reason not to go down this route instead..
With regards to the hardline and AN fittings, it's really not as hard as you might think. You slip a nut and sleeve into the tube and then single flare the end of the tube to 37deg. Below is what a typical assembly looks like. On the far right is the tube flare, then in the middle is the sleeve, and on the left is the nut.
For flaring, I use a Ridgid 41162 377 flaring tool which can do up to 3/4" (-12) and cost about $100. It has an eccentric anvil that rolls around the tube to make the form rather than trying to form the entire flare at once. The Eastwood tool you bought doesn't go up that big - I think it maxes at 3/8" (-6). For the fittings themselves, I prefer to use steel JIC fittings, sleeves, and nuts. JIC uses the same 37deg flare as AN, it's common to hydraulics, cheaper, and less likely to be damaged (steel vs aluminum). You would also need a quality bending tool. I like the Ridgid 400 series benders which are available up to 1/2" (e.g. P/N 36132 model 408). You'd need to check if the bend radius will be tight enough, recognizing that you will need some stickout on the end for making the flare. From your marked-up photos it looks like you have enough room for that routing but it's really hard to say.
Something I'm not familiar with with turbo oiling is how do you control the flow/pressure so you don't lose system pressure for the rest of the engine? Where do you source oil for the turbos? Is a big 1/2" return line really necessary? If you are flowing enough oil to necessitate that large of a line for both turbos, aren't you robbing a lot of oil from the engine?
As they say, "please Like and Subscribe!"
Andrew
For turbo's and engine system oil pressure, a journal bearing turbo will produce the necessary restriction in the turbo center section to prevent the turbo from "bleeding off". For ball bearing center section turbo's, there is a necessary fixed orifice restriction that usually comes installed in the turbo center section inlet from the factory, to introduce restriction and prevent oil pressure bleed off.
What I'm also thinking is with all this new-found room, I might try to use a 90* 1/2" NPT male to -10AN male adapter, clocked forward and upwards 45*, and then use a hose with 45* -10AN end to clear the subframe (if necessary) and prevent making hard lines. I will test fit all this stuff this weekend and see what looks to work best.
You may also want to look into a specialized hose end. Various manufacturers make a swivel hose end that has a built in NPT on it, instead of the usual female AN. Like this:
https://www.summitracing.com/parts/s...118b/overview/
Andrew
Andrew
