LQ4 into a 3rd Gen/1972 Nova
Bandit - just step on the accelerator to get out of the tunnel as fast as possible.
Started gutting the dash panel to make room for the instrument cluster...
Imagine that they mate to flat plate right above where the round black pieces are sandwiched in there...
Made this back in the summer, pretty hard when you only have a bench vice, some 4" tubing, and a big mallet...
Of course it fits perfectly...
Got a couple more gauges that will go in the way-less-custom hanging 3pack panel. The sure do look cool (IMO)...
Just for ***** I made a couple toggle switch separator do-hickies, they took a lot longer to machine than they'd look, but I think they add a tiny bit of modern class that'll go with the modern gauges & machined aluminum bezels...
Also, car complettion isn't looking too hot since this is in my near future
Before...
After...
Randomly decided to start working on the interior. Apart from a couple ACC splices and stereo wires, this's all the previous owner(s) handiwork, geez more stuff to clean up...
A while ago I picked up a tilt column from an '80 Camaro for dirt cheap, and figured if GM were smart they'd keep a good thing going and have as many parts interchangeable as possible.
Looks like I was right, the '80 Camaro column (top) is damn near identical to my stock '72 Nova column (bottom)...
Except for the output shaft attachments...
And firewall cover plates...
Thanks to Marktainium, picked up this 1 1/8" power brake aluminum master cylinder for cheap, looks nice on there...
Old manual brake rod is 5.25" long from firewall to pivot point...
New setup is 5.75" from firewall to pivot...
...I think I'm gonna make a custom brake/clutch pivot bracket moving them closer to the firewall for my long legs (I'm 6'2"), so I'll have to figure out whether to shorten the rod or not, more on that later.
http://www.mbmbrakeboosters.com/inde...emart&Itemid=6
MillsMotorvation... All of the gauges are electric and have on-board chips so they run independently, just need switched power and ground for the lights & processor board, and of course a connection to the appropriate electric sender.
