LQ4 into a 3rd Gen/1972 Nova
Seriously though, you could weld it up at your work. I tried but as it cooled the welds kept cracking. I ordered a new one.
Also, I did think of making my own pan, whether it be sheet steel or aluminum, but it'd be too much work to mill my own flange for either material. And cutting the flange off my used one would be out of the question because there would be so little material left, that even with good clamping and copious tack welds, I'd be afraid that the cast flange would warp. That is also not to mention sandblasting & scotchbrite cleaning the entire flange perimeter, which wouldn't guaruntee that the porous cast aluminum was clean, oil can soak in and weep out quite a lot.
Now I just need to create two oil return/drain holes into it and it'll be over with haha.
Sharpied area is what would still have to be chopped and removed to clear short idler/pitman arm assembly on my Nova, making my draglink stick out the furthest back from the crossmember. Sharpied area extends about 2" into the pan, towards the back of the pan.
I modded the bolt-on tray thingy that keeps oil in the sump and made it more badass, probably gonna tack in a v-shaped baffle like the fbody too.
Always liked the crinkle paint look on valvecovers, dunno why, makes the engine look a little more different than normal. Pics definitely don't do the finish justice, the end result far exceeded what I was expecting out of a spraybomb can.
Supporting plate to go on engine side of firewall, to space the M/C out from the firewall a bit to give clearance to unscrew the reservoir cap, as well as to add rigidity to the enginebay side of the firewall where the brake pedal bracket bolts to the firewall.
Also has a pocket milled into it so the bracket for the combination/proportioning valve can flushmount behind it.
I'm cheap and think I threw out my old cast iron manual M/C, so I just made my own pushrod/clevis for the 240SX brake pedal. Clevis pivot hole is drilled so the bolt is a tight hand press-fit into the clevis, but the brake arm hole has a loose clearance fit so things rotate freely. The nut on the bolt bottoms out on the shoulder of the bolt before pinching the clevis giving everything nice easy rotation, and I also drilled a cotter pin hole so none of this jiggles loose and I loose braking connection.
Clean, compact packaging with a non-descript raw aluminum look.
Having access to an end-mill and lathe is great, ain't it
Love when the boss goes on vacation
Nice work !
