LQ4 into a 3rd Gen/1972 Nova
Finally coming together
Looks like I have to take the trans off yet again to modify the clutch master/slave hydraulic line, it's about 1" too short... arrrrrg. Might as well just pull the entire engine yet again, **** I thought it was in there for good this time....
HA HA HA HA HA HA HA HA HA HA HA HA HA HA HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAhahaha hahahahahahaha ha ha ha ha ha ..... ha ha-and the clutch worked fine for me........
I actually read of several people having the same problems, and it somehow leading to a grind in 4th occasionally from the syncro. Guess what, mine started doing it too bout the same time.
What kind of hydraulic setup did you use?
While I have the engine in for final mockup, made lines for the Heidt's power steering pressure relief valve (to adjust "feel"). Knowing how this build goes, I'll probably end up not liking it and just get a TurnOne pump and fully re-worked box later down the road, but for now I just want to drive it...
Red&blue will be sanded off and bracket I made will get painted, just mockup...
Annnnnd need to make the downpipe ASAP while the engine is in the so I can send the hotside off to get ceramic coated soon...
Good clearance seeing as I didn't have the physical idler pulley when first fabbing up the piping...
Wastegate dump pipe merging into the 3"->4" downpipe transition...
Tight but it fits with about 3/4" all round in there...
Are you modifying your existing engine harness or are you going to buy one already done? I figure you will be doing your own but just thought I would ask.
You have taped off every hole to prevent trash from entering but your intake ports are wide open. Hope you dont have any jealous friends that might drop you a bolt or nut down the intake like we have happen at the track. Now somebody has to be at the car when it rolls off the trailer until its pushed back on. A wood screw was the culprit and it damage the piston and the head.
I have read you can use lye or crystal draino to remove the anodized coating. You have to be careful about the time left in the solution & wear gloves & well ventilated area. Might be better than sanding.
I've decided I will keep the finger weights on... for now. Marktainium had the clutch before me and reported zero vibration or weirdness issues, so I will try my luck at it the way it is.
Plus I also don't have to pull the trans to lengthen the clutch hydraulic line... I conveniently completely forgot that there is the quirky quick-disconnect in there... engine is still in it seems for good!
Downpipe completed up until framerails/floorpan, going to hopefully bang out a new trans x-member and y-pipe this weekend so that all exhaust things turbo related are ready to go to the ceramic coating place on Monday...
Joe, down pipe is looking good, looks like an old 2 stroke expansion pipe! One thing I noticed though, where your pipe goes by the idler. I think I would put a heat shield there. I'm sure you will coat it or wrap it, but I think I would put a stand off metal heat shield there. You don't need your drive belt snapping when your pipe hits 1000*
Stock...
...modified stock to all I need...
Location of pressure sender is AFTER the oil cooler, so that it reads the oil pressure that the engine block sees, and also would report pressure problems if oil cooler conks out somehow...
-8AN steel bungs welded onto lines, to have some flexy lines going to the oil cooler. Again, the TIG welder is so far the best tool I've bought by far.
And it was kindof flexy, but not in a dangerous way.
And it had a lot of 90 degree features that didn't look the fanciest.
And it was MIG'd so it wasn't the prettiest. Like everything on this build, the first time is a new part of the learning curve, and I wanted to redo, so I did.
First step was to make a reference point for the lowest that anything could hang, be it x-member or exhaust pipe, which is represented by the top of the 1"x2" clamped in there...
Benchtop vice & hacksaw mitering is very classy..
Decided to make a dedicated turbo x-member this time, but still have clearance for dual 3" pipes to not hang below the subframe rails (tall order without subframe bushings)...
More fancy smancy mitering & stuff..
If there's ONE thing I've learned from all this car welding and machining/jigging at work, it's clamp clamp CLAMP...
Turns out there's good ground clearance with dual 3" pipes, but a 4" single would slightly hang below the subframe rails at that location, so aim is to have the single 4" -> dual 2.5" split before the trans x-member.
