LQ4 into a 3rd Gen/1972 Nova
So it's the decision of whether to have both sides have plug wires facing up, or to flipp the driver side and have both sides face in towards the engine. I'll mock the flipped one up and see how it looks.
Also, making a custom location for the brake master cylinder, and using an intermittant wiper motor so I'm gonna move that on the firewall to between the brake master cylinder and the driver side fender, and just extend the linkage underneath the cowl.
Powder coating & heat treating oven at work, figured might as well go all the way and pre-heat the **** out of the pan to minimize warpage as well as work some more of the oil out of the cast pan even though I already sand blasted & scotchbrited it...
Welder at work did it this time, my machine at home has nowhere near the capacity running on only 110V currently...
Still have to drill & tap for a drain plug & two oil return fittings (1 for turbo and 1 for oil breather/separator/catchcan).
And I might even just use the oil level sensor itself as the drain plug haha.
Wow, is there any chance you could make one of those for me too????
LOL. good idea.
kendogg... I could make one for you, I still have the sketch I made for it. You wanting just the blockoff part without the extra threaded boss? Shoot me a PM.
I need one, and have yet to find anything suitable.
