LQ4 into a 3rd Gen/1972 Nova
Mark... Plan all along was to make sure hood clearance happened... I still posted these options up because in prettymuch all of them, if I had to make my own bracket to relocate the alt, the alt wouldn't have to be lowered by too much so it shouldn't alter any of these options too much.
Going to mock up the hood tomorrow after work. I'm going to be shocked if the hood fit the truck accessories STILL even after I removed the subframe bushings...
squee... I'm not sure on a 4th gen to be honest, you'd likely have to make or buy an adapter for the hoydroboost to make it bolt up to (I'm assuming) the 4 bolt pattern the 4th gen brake booster uses to mount to the firewall. Another guy is already interested but I'll PM you if it happens to fall through.
This sensor was the only thing getting in the way of the hood fully closing... anyone know what it's for??
And a bunch of the plastic bs on the intake is all that comes close, will trim off and make it look a bit better...
Welds are improving a bit
Idea is to go from the TC76's 3" outlet to a 4" to eliminate backpressure. Wastegate dump pipe will merge with downpipe right at the cone section.
Like hell I'm paying $25-30 for a cone, just needs a bit of garage engineering...
Made a grommet/plate thingy for the wiring harness to pass through the firewall... will cover up & seal a 2" hole...
Tightened the 1st nut down hard then put the 2nd nut on there to protect the threads/block, then rotated flexplate till the bolt/nut hit it...
Lonely looking, this is gonna be a lonnnng weekend of wire wheelin' and cleaning so I can paint it.
Nice work on the firewall ferrule! How will it attach to the firewall?
The firewall thingy work like this: the split front piece goes around the harness on the engine bay side of the firewall, the slotted back piece slides over the harness on the cockpit side of the firewall, then the bolts screw thru the front piece into the back piece, sandwiching the firewall between the machined step in the backside of the front piece and the lip of the back piece. Pics will help it make sense when I install it later.
Figure it's best not to leave it to just those 6 bolts to hold onto the engine, so welded the stands in...
TIG welder is by far the best investment I've made so far, and the rolling cart is by far the most useful thing I've fabricated yet, it's so easy to make accessible...
Not the cleanest welds but I had to change to at least 196 different straddle/crouch/hunch positions to get the angles...
And then I started playing with aluminum...
And started making a coil relocation bracket. Making (more like replicating) the bends was NOT fun but will be worth it, ran out of Al. plate today, but the first one turned out better that I was expecting.
Was originally going bolt to the side of the block below the manifolds but now I kinda want to show it (them) off either on the firewall or bolted to the back of the heads hovering over the aft end of the valvecovers...
