LQ4 into a 3rd Gen/1972 Nova
First, got the wastegate welded on, so hot side is officially finished from manifolds to turbo (except for grinding/smoothing the inner perimeter of the turbo flange and the ceramic coating). The pics are deceiving, there is a good 1.5"+ clearance between the aluminum diaphragm cover and the passenger side hot pipe...
ROUGH mocking up cold side, just wanted to see overall what it'll look like. Need to finallize bends and order up some black silicon reducing sleeves and 90's...
And they are black with red stitching to match my steering wheel and gauges.. haha. Anyways, a little mockup just to tease myself with what the interior will look like...
I have no idea what truck pedal he used, but the only "cut" part on it I could find (aka where the stock pedal would have been previously) extended up from the top... I have no idea how that'd work. But I compared it a shitload to pics of my old pedal and other than the pedal arm seeming upsidedown, it seemed identical...
Mocked it up on the bench and climbed up there to test the pedal arm length AKA the pedal throw/travel, from zero to WOT, felt good...
First as always, break out the cardboard to template it up...
From various 240sx/s13/LS1 swap threads, it seems for the stock 240sx clutch pedal, a 3/4" bore master cylinder works best. I had originally wanted to use a stock 240sx master cylinder too for ease of fitment, but it is a 5/8".
So I decided to modify the Ram '98-'02 Camaro master cylinder I had, this included chopping off the threaded rod & clevis from an old 240sx master cylinder I had lying around, and welding it onto the Ram MC at the appropriate length, to keep the same MC rod geometry as a stock 240sx MC, which the 240sx clutch pedal is designed for...
Once the proper 240sx rod length was replicated on the Ram MC, I then made a bracket to position it properly relative to the clutch pedal...
And the resulting overall "pedal plate" that just needs to be trimmed, then "cut & paste" into the Nova firewall...
Other idea for a temporary shifter was to just cut off a hockey stick handle complete with tape & ****, but that might be a bit too Canadian haha.
bczee... The hydroboost is off of a 2005 Colorado, and the master cylinder fits it perfectly and is a 1-1/8" bore unit, all aluminum. Was thinking $100 for the hydroboost and $160 with the master cylinder, plus shipping...
kmracer... Thanks! Been a long road but I'll have 6 months straight with it this summer, but hope to have it on the road within 3-4 to enjoy some sunny cruising. I actually think it'll be doable, the list of big items to finish is slowly getting knocked down...
Continued turbo plumbing mockup to see what I need to order.
Going to have to notch the inner sheetmetal on the passenger fender so I can rotate/clock the compressor housing a little bit more up, to clear the stock inner fenderwell....
Potential BOV location. Other orientations would work but this is the only one that would allow a recirculation tube back to the intake, if I so chose to make one (still on the fence)...
Nice direct pump outlet to rad, with a trimmer stock S10 45* lower rad hose to connect...
Good amount of clearance for upper rad hose too...
Possible recirculation pipe layout for BOV...
I need some opinions on which layout is best. Most don't offer a huge amount of belt contact on the crank pulley... I don't like that. Most also place the belt fairly close to the waterpump return inlet.
Since I'm running no subframe bushings, I doubt my alternator will clear the stock hood now, so I will likely just make a new plate to mount the PS pump & alt to, keeping the pump in roughly the same place, but the alt could move down and/or outboard quite a bit and still clear the driver side hotpipe...
Option #1 (not good)...
Option #2 (also not good)...
Option #3 (slightly better)...
Option #4 (pretty good looking)...
Option #5 (too crazy of a belt wrap?)...
[IMG]
[/IMG] Last edited by tsnow678; May 3, 2011 at 03:57 PM.
