LQ4 into a 3rd Gen/1972 Nova
Old 07-31-2012, 08:34 AM
  #921
Chicago TDP's Avatar
CLEAN BORES!!!
Just drop that oil and slap some Clevite bearings in there and LS9 gaskets under the heads and put some boost to it!!!
Old 07-31-2012, 11:24 AM
  #922
SIC LSX's Avatar
love this build and car but im not feeling the wheels
The following users liked this post:
408GT (10-08-2022)
Old 07-31-2012, 11:31 AM
  #923
-TheBandit-'s Avatar
Wait until the shop checks it out before you order pistons. 4.005 is done with hone only. If the crank journals and rods look good, you might consider getting a set of rod & main bearings, checking the clearances and putting it back together with all the stock stuff. That will save you a whole bunch of money in machining and component costs, but you really need to check things out thoroughly. It would suck to put this together and get bad oil pressure right off the bat.
If it were me especially with the turbo I would build it with forged stuff, but you can put those decisions off until you see what's rattling around in there.
Old 08-01-2012, 01:22 AM
  #924
frojoe's Avatar
Oops! Sorry!!
Old 08-01-2012, 11:42 AM
  #925
I like the wheels. Took a long time for me to get used to big, modern wheels on these cars, but now that I've warmed up to them, I really like them. Yours look great, especially with the new stance.
Old 08-01-2012, 05:39 PM
  #926
hookemdevils22's Avatar
light scoring on a couple of the bores. probably only needs a decent hone at the worst (since you'll have it out for the bearings anyway).
man, I don't know how you or clint do it. I'd go f'ing insane with the 'one step forward, two steps back' you two have been experiencing.
another thumbs-up here on the wheels. i've been trying to find something similar yet different so i won't be accused of copying you. any idea on the weights?
Old 08-02-2012, 12:20 PM
  #927
frojoe's Avatar
"It'll all be worth it" and "it's a labor of love, right?" are the two that I keep getting told and have to keep reminding myself of, haha.
Old 08-06-2012, 10:51 AM
  #928
LoRollinLS's Avatar
I just found this build today as I am new to this forum. This is a great build, love the car, love the engine, and the whole bit. I hope your rebuild goes well. I would think the LQ4 block to hold up under boost better than the LS2 alum. block, am I right?
Old 08-06-2012, 11:10 AM
  #929
Jimbo1367's Avatar
LOL. I bet that gets said ALOT by boardmembers here. LOL
Old 08-06-2012, 03:55 PM
  #930
tsnow678's Avatar
I think that we try to fool ourselves into thinking the long hours working on these old cars and the tons of money spent on them will be worth it in the end but the reality is "they are never done". It is a disease that will consume every part of you. If you don't believe me ask my wife. 18 years and counting owning my car and it wil never be done. Do I really think its worth it, hell yeah! The smile on your face will say it all!
Old 08-06-2012, 04:32 PM
  #931
tango68ss's Avatar
AMEN to that!! They are NEVER done!! Just going thru iterations....
Old 08-06-2012, 09:40 PM
  #932
Marktainium's Avatar
I like to wash my car.
Old 08-10-2012, 11:02 AM
  #933
frojoe's Avatar
Parts! Everything except pistons which were drop shipped from Wiseco so still waiting on those, and a couple little gaskets that I'll pick up from a local dealership.
I've attached my Excel master spreadsheet of all the research I've done for pricing on stock-displacement forged rotating assembly, in case anyone is interested.
I really lucked out and Summit had a limited sale on ARP head studs for $259 (down from $309) which is the cheapest I've found them, but appears the sale only lasted a couple days.. guess that was good timing!
Another helpful tip, for almost any GM replacement part, and a limited amount of aftermarket LS stuff, www.PacePerformance.com has the lowest GM parts by far, it's actually pretty crazy.. the cost of all the miscellaneous little plugs and sensors and gaskets can really add up.. so buy from Pace!
Parts:
- Texas Speed rotating assembly ($300 savings over buying parts individually): Wiseco 4.005" -11cc pistons, Callies Compstar H-beam con rods, Eagle forged crank, Clevite main&rod bearings
- ARP main & head studs
- LS9 head gaskets
- Patriot Gold springs
- Comp Cams hardened pushrods
- some Comp Cams break-in oil
- engine rebuild lube kit
- assorted gaskets
Total cost in parts to rebuild engine re-using LQ4 block: $3363
Shipping was $12 for Summit & $90 for Texas speed, bringing total parts cost to ~$3465.
Attached Thumbnails LQ4 into a 3rd Gen/1972 Nova-0809021920_2.jpg   LQ4 into a 3rd Gen/1972 Nova-forged_engine_rebuild_scrnsht_simplified.jpg   LQ4 into a 3rd Gen/1972 Nova-forged_rotating_assm_excel_screenshot.jpg
Old 08-10-2012, 11:06 AM
  #934
frojoe's Avatar
I've attached my Excel spreadsheet with all the part possibilities/part numbers/prices that I've researched, but the forum wouldn't let me upload an Excel .xls file, so if interested, save the file and rename the filetype from .TUN to .XLS
File Type: tun
Old 08-10-2012, 11:14 AM
  #935
Also, GMPARTSDIRECT.com has CHEAP parts too....LS9 head gaskets for less then $40 a piece!!!
You can order a brand new LS6 cam for $180!!!
And, LS7 lifters are cheap there too!
Just a note, you can get the ARP head studs from $200-$250...
I am putting another boost motor together right now and bought all of my parts at the locations listed above...
Old 08-10-2012, 11:41 AM
  #936
frojoe's Avatar
Thanks! I had no idea.. I had heard of that site a while ago but totally forgot about it haha
Old 08-10-2012, 03:27 PM
  #937
squee's Avatar
Pace really does have GREAT prices on certain things. I bought a set of LS3 assembled heads for $330 a piece. I think they were actually less than or right at $300 a piece when I bought them, but they've since gone up to $330 a piece. I actually only needed one bare L92 head, but the LS3 heads are the same casting with better valves, and the L92 heads are actually $430 a piece currently. When I bought them though, the assembled LS3 head was actually like $90-100 less than a BARE L92 head! Thats crazy and makes no sense, but its a STEAL. You might consider looking into them actually since you have a 4.0 bore. Of course you'd need a L92 truck intake, but you can pick those up cheap.
Old 08-10-2012, 04:40 PM
  #938
What about machine work?
Old 08-10-2012, 06:37 PM
  #939
Squee, are you serious?! That's ridiculous of LS3 heads are $660 a pair. Just ludicrous.
Old 08-10-2012, 06:41 PM
  #940
Edit: that is no joke. wow. Mind=blown
Quick Reply: LQ4 into a 3rd Gen/1972 Nova
