LQ4 into a 3rd Gen/1972 Nova
With having the return from the fpr, you need to make sure that it returns below the fluid level so it doesn't aerate the surge tank. The surge tank should hold enough fuel during a pass that the low pressure pump would have a head start on the larger pump(s). I have seen the return from the fpr plumbed both ways online (one way to the surge tank, and one way to the main tank).
My LTD was setup from the factory with a two pump system. A low pressure in-tank and high pressure one external on the frame rail. I actually have a brand new low pressure one in my tool box. I didn't use it because I don't think it's compatible with E-85. I should have just tried the low pressure pump one time just to see if it made a difference.
I made a vent for my main fuel tank using a rollover vent from Summit and putting it in the filler neck. I ran a piece of hose off the top of it and vented it right beside the overflow tube from the fill cap.
Good luck and keep us posted on what you come up with.
408GT.. you raise a good point, but you must not know me well.. I like making stuff haha. I'd want a cylindrical surge tank since it's the best for flow when combined with inlets & outlets that are tangent.. it's going to have a good amount of fuel flowing into and out of it thru multiple fittings, I'd rather make the flow as least turbulent as possible. I'd also want to maximize space, and with the design of dual pumps + brackets holding them + a nice sturdy bolt-on top lid for access with a good Viton seal.. all signs point to me just making one.
The Internal Combustion Fundamentals is definitely scientific.. I'm surprised it doesn't have calculus in it. The Forced Induction Performance Tuning is very informative and technical, but not boring.. still learning some things from it page by page.
I have a couple more books on the way, not as textbook-y as those two but should be good reads.
I have seen some examples for SBC that pass the two crossover tubes under the oil pan, but it's almost always spaghetti and by the time you achieve equal length primaries (assuming that's your goal), they're too long to be effective in any useful RPM range.
But please keep us posted, because I would like to see what you come up with!!
