LQ4 into a 3rd Gen/1972 Nova
Actually you only need low pressure transfer pump coming from the main fuel tank. You vent the surge tank so it is at atmospheric. Your main pressure pump(s) lives in the surge tank. You can either have the pressure regulator return dump back to the surge tank or go all the way back to the main tank. Returning to the main tank allows the fuel to cool back there so there is always a supply of cooler fuel coming into the surge tank. Surge tank provides a favorable aspect ratio and a consistent head (amount of fluid above the pump) to maintain an air-free supply of fuel to the engine, even when the transfer pump is delivering air.
How do you vent the surge tank? Is there a return that goes from the surge tank back to the main tank, and that's used as the vent?
Would you not want to have the transfer feed line enter the bottom of the nicely medium diameter & tall height tank and have the return to the main gas tank near the top, and thus keep it a closed loop surge tank and have the gas tank vented? I'm currently having venting issues with my gas tank.. I think the vented cap is stuck, but I'd like to have a filtered and check-valved vent line from the top of the gas tank to insure that it truly is open to atmosphere with no residual pressure in it at all.
I think maybe in my diagram above that I should have run the return from the regulator back to the main fuel tank. My intank is a 340 lph and my inline is a 4303, but now I'm going to run the 340 all the time and have the 4303 come on under boost.
The more I think of it, the more I like this idea.. my current setup works almost all the time, which means my main tank baffling is more than adequate for a transfer pump so I wouldn't have to touch the tank inners or bulkhead or even pump bracket, just move the 2 high pressure pumps to the engine bay and find a suitable low pressure pump. Having a hard time finding a high volume low pressure in-tank electric pump tho, seems almost all available are high pressure EFI pumps. Having a single low pressure pump in the main tank means less fuel squishing, which means less heat in the main tank.
I like the idea of a swirlpot in the engine bay with inlet-outlet ports tangent to the OD of the tank, creating [hopefully] a less turbulent fuel flow. Make a nice heat shield for the surge tank with maybe some ducted airflow, and the tank could potentially be cooler than the main tank near the tailpipes in the back.
http://weldingweb.com/showthread.php...-dual-walbros&
With the air filter (single one now, but two in the future with twins), intercooler piping, headlight wiring, and the general shortness of the Nova's tiny front overhang, I don't really think there's room to jam it behind a headlight.
I'm thinking it could go where the heater blow motor is on the passenger side of the firewall under the front fender, kind of like where a lot of dry sump tanks are put on pro touring Camaro's, except due to the smaller size have in in front of the firewall and not in a sheetmetal'd recess.
Also, you can see where my fuel hardlines and FPR currently are.. stupid huge heater box needs to go bye-bye!
I think for the surge tank the feed line from the gas tank should be fairly near the top where the return line to the gas tank would be, that way when the car is parked the whole volume of the surge tank (upwards of a gallon probably) doesn't gravity drain back to the gas tank, and potentially overfill the gas tank (if it's a full tank) and run up the vent tube. I bet the above vent would work decently for quick sloshing, but wouldn't seal well against constant pressure head from an overfilled gas tank. I'd put a drain fitting on the bottom of the surge tank to drain it in the case of maintenance.
Then again, I could lay the twin hi-pressure pumps on their side thus raising the intake socks up from the very bottom to maybe 1" above since they'll be guaranteed to be submersed in fuel, and the transfer pump can be on its side as well because air intake isn't such a big deal. But in the end, I really don't want to modify the welded setup in the gas tank.
Since it would be a direct drop in, I could add a hi-pressure pump in the existing mounting bracket and used that as the transfer pump. Then move the existing TRE 300 pumps to the new surge tank. Not a single thing, including wiring, would need to change for the main gas tank. The kicker is I still have my original Aeromotive Stealth 340 pump which wasn't actually the problem when "my fuel pump died" the first time, it was the wiring and tank bulkhead that failed.. so that could literally just drop in and be good to go.
From my research, it seems a hi-pressure pump with the same body as the Walbro 255 will flow just fine in low pressure applications. I was worried that continual low pressure would mean continual high gear RPM and maybe premature wear, but then the load just be very minimal so maybe it'll all be okay in the end? Also the low load of a single pump would mean much less heat input into the main tank, so that tank would be cooler than the surge tank and possibly help keep the surge tank cooler.
I made my in tank can with a flapper valve in the bottom of it, So that fuel will always be at the level of whatevers in the tank at a minimum. So If I ever had a failure of the lift pump, I wont be stranded.
On a side note.. I've never been happy about the operation of the stock style floating lever arm level sender, and want to change to a vertical float or impedence style tube.. does anyone have any experience or comments on this or other style of aftermarket/racing level sender?
