Taking the plunge: LS3 into '64 Tempest. Need help with shopping list.
Old 08-13-2010, 09:43 PM
  #221
b-man64's Avatar
Originally Posted by speedtigger
Do you think that your starter would go in if the pan did not have the "kick out"? Do you think you could get the starter in and out if you had the JZ Motorworks pan as it goes straight down and does not have the kick out area?
I have the Edelbrock mount system and was going by the same pan and headers, but no way in heck will I consider a system that does not allow me to service the starter without pulling the trans..
I don't think the pan kickout makes much difference. The crossmember blocks the starter from coming in at the front, the trans bellhousing interferes at the rear and the headers wrap very close around the starter motor.
That's hotrodding I suppose, when you're using a lot of aftermarket parts these kinds of problems sometimes crop up. From what I've heard the LS-series starters are very reliable, so once mine's in I'm hoping it will stay in.
Old 11-11-2010, 11:58 PM
  #222
jomomma's Avatar
any updates??
Old 11-21-2010, 07:55 PM
  #223
b-man64's Avatar
My project is unfortunately on hold right now.
Too many things happening right now that take precedence over having fun with cars.
I started this thread with three main objectives; To gather information on how to go about this project, to share my work to help others taking on similar projects and to help me stay motivated so I could see this through.
I will finish the Tempest, but not for a while.
Thanks for looking, Bart
Old 11-21-2010, 07:58 PM
  #224
Project GatTagO's Avatar
Received 1,441 Likes on 909 Posts
I hope everything is alright in your world.
Andrew
Old 01-08-2011, 09:16 PM
  #225
zdawg28's Avatar
stumbled across this thread by an engine harness search. Got really into it and read all 224 post took about an hour of my time and learned a lot about building what you really want not whats always available. As a NAPA employee i noticed some stuff like the red metric bolts and brake lines, pretty cool build hope you get to finish her one day and reap all the benefits.
Old 03-10-2011, 12:07 PM
  #226
'02TA's Avatar
I love how you mounted the coolers and ran all the hardline instead of using rubber hose. Very nice build. I like the bracket GTO as well. Good luck with sorting out everything.
Subscribed
Regards,
Ryan
Old 07-06-2011, 10:21 PM
  #227
Rocketrod's Avatar
Awesome build!
Old 07-14-2011, 02:53 PM
  #228
NO CATZZ's Avatar
I have read through this thread several times and I must say your build is amazing...and inspiring since I am planning a LS swap in my 65 Skylark. I hope everything is OK with you and your family and hope to see you get back to your build soon. Sending a PM with some questions.
Old 06-16-2012, 04:52 AM
  #229
arieswebb's Avatar
Default Great thread any updates..
Just wanted to say that's a awsome build you have going on
It's a great motovater...I'm almost done with a 77 vette restoration..
My new garage will be done in @ 2 months then is time to do a ls3
In my 64 temp/gto clone..I got this car when I was 15..
26 years ago..
You have mad skills keep it up..!
Bob M.
Old 06-17-2012, 03:46 AM
  #230
Killer66's Avatar
Bman64, I don't quite understand the POR15 and fiberglass. I know it's your build, but isn't lead or spot welding better than the POR15 and fiberglass? Especially in the window channels? I'm curious because my Buick has a lot of work and I need to buy shop tools, welder, air compressor etc... Thanks in advance
Old 03-18-2014, 10:42 AM
  #231
brutalis's Avatar
Bringing up a dormant thread, just read through the whole thing. What a cool build! Hope you can get back to it soon and finish 'er up. Best of luck.
Old 05-22-2014, 10:13 PM
  #232
TTA89's Avatar
Coming up on 3 years with no progress. This is how things go sometimes... I hope all is well and you'll eventually get back to it.
Old 03-27-2021, 07:50 PM
  #233
Von Neal's Avatar
Default LS is for someone that can’t build a Pontiac
http://hotrodenginetech.com/495-cid-pontiac-powerhouse/
Old 03-27-2021, 09:21 PM
  #234
Received 3,121 Likes on 2,434 Posts
You joined here just to promote an obsolete engine??
Old 03-28-2021, 07:30 AM
  #235
I've been around way too long to even pretend I need a flame suit. Please crawl back under which ever rock you crawled out from...or might I suggest joining the echo chamber of the Performance Years forum...
Andrew
The following users liked this post:
G Atsma (03-28-2021)
Quick Reply: Taking the plunge: LS3 into '64 Tempest. Need help with shopping list.
