Lowered convertibles
hose, against Hotchkiss fronts for a decent-
looking rake. You might try the same, it's an
easy enough swap and stock springs cost
about 25% more than their weight in dirt.
Sig pic is with Hotchkiss all around, same
butt-too-low look you're not liking on yours.
That said, I went with GoldLine springs on my SS. When I ordered them I remember being told they were avail if differing drops. I went with the 1.75" drop for my car, but I could swear they also had 1" 1.25", 1.5" and 2". The cost was way reasonable and I am very happy with both the stance and the ride they gave me.
Yes, 1.75 drop kit, was about $200 for the set of springs. Didn't change the shocks, but I did run a fully adj. panhard bar, had to else the rear end was off center. I went with the UMI bar.
When I autocrossed the car, I was able to confirm the car is on throttle loose, IE, the car is easy to throttle steer, I was able to drift the car out of most turns, not the fast way around the track, but certianly the funnest(is that a word?)
