Wits END with this window...
So, my plan now is get some 3M glass glue and pop the top enough to match the glass back with the inner 'liner' fabric and glue that back together. Then I'll get some sort of tape to reinforce the glass/fabric seam on the inside.
What does anybody suggest to get rid of the gap between the outer fabric and the inner piece? I could just use some double sided body tape to stick the layers together above the window....?
What I'd recommend is using a whole mess of pillows,
foam, whatever, to push the window out to proper
position against the outer fabric so it's wrinkle free
before you apply the glue, and let the outer work set
before you try anything with inside pieces.
But if you used silicone already you may never get
adhesion back.
Don't ask auto parts store dudes for advice unless
they're over 50 and missing a finger. Those might be
ex-mechanics. The rest of them are just taking a
break from flipping burgers.
Too funny. And true. I got fed up and used a piece of black duct tape for the time being.Super ghetto. Don't care. Cost 1 penny. Good enough for me at the moment. I think I will go at the glass with some solvent, a razor to scrape and try with the 3M urethane in a few weeks. Worst case scenario, it doesn't work and my window is still flappy!
