Convertible Vehicles Enthusiasts | Information | Maintenance
Eliminating squeaks
Old Feb 17, 2007 | 09:49 AM
Goldstreak65's Avatar
Default Eliminating squeaks
My Convertible top queakes something terrible when going over bumps, is there some way to stop this. Are there certain joints that need to be greased?
Old Feb 19, 2007 | 07:41 PM
jimmyblue's Avatar
Moderator
I would start with the rubber bits, the weatherstripping and
the drain pads at the rear of the doors. Silicone grease
(like distributor grease) all the rubber you can get at, just
enough to get it looking clean & black and wipe away the
excess.
Old Feb 21, 2007 | 11:25 PM
Will do thanks, for the input.
Old Apr 4, 2007 | 07:41 AM
scottso's Avatar
How did you make out Goldstreak65? I know I was able to knock out a lot of "rattles" and metal on metal sounds by tightening and re-padding a couple of worn areas.
Old Apr 4, 2007 | 08:33 AM
hugger427's Avatar
put on a loud exhaust
Old Apr 21, 2007 | 12:56 PM
Irish350's Avatar
yeah, my car squeaks somethin fierce over even mild bumps (driveways and speed bumps, but also drainage dips in the road, at lower speeds)
Old Apr 21, 2007 | 06:22 PM
XLR8TOR's Avatar
I can't hear any squeaks over the stereo, exhaust, and screaming passenger.
Old Apr 22, 2007 | 10:02 PM
hardcorebob's Avatar
Mine squeaks, rattles, and moans especially over road humps. I've had the chassis lubed a few times recently and it's helped some....but some are still there.....
Old Apr 23, 2007 | 07:52 AM
scottso's Avatar
It is a labor of love - I find one rattle or squeak and fix it , only to hear another one a few days later .
I really only have a few days at a time where I can say there's nothing making noise. Forget cold weather, ugh! Warm weather is here, lower the top, and turn up the stereo and they all go away.
Old Apr 26, 2007 | 10:06 AM
DANOZ28's Avatar
my inside door latch / locks squeak. the driverside is real loose in the door panel . can any body shop just fix that? hope i'm not hijacking a thread.
