Convertible Vehicles Enthusiasts | Information | Maintenance
deleting the cats
Old Mar 19, 2007 | 11:10 PM
35thANNIz28's Avatar
Default deleting the cats
i just recently got rid of my catalytic convs....... bad idea.....the car idles roughly at dead stops...srvice engine came up....... the obnoxious smell of gasoline is killing me...and i really don't like the noise......can this mess anything up????/and once i put the cats back...wil everything go back to normal??? thx
Old Mar 19, 2007 | 11:37 PM
camarojunky74's Avatar
well i really dont think this will damage anything, if you put the cats back on everything should go back to normal. also there is companys that make high flow cats you can put them on instead.
luke
Old Mar 19, 2007 | 11:40 PM
Josh2006's Avatar
Check the External engine section
Josh
Old Mar 19, 2007 | 11:42 PM
Josh2006's Avatar
Well all of that can be fixed with a tune. The reason your SES light is on is because the Rear O2 sensors are reading that the Cats are not doing there job, since they are missing. You should check out the external engine section there is all kinds of stuff about not having cats. oh and by the way putting any cats on there besides the stockers will leave you in pretty much the same boat, SES light will still be on and you will still have some smell and it will still be louder than before.
The other thing is you really wont mess anything up other than the atmosphere and you will be running a little rich but not enough to really hurt anything.
Josh
Old Mar 20, 2007 | 02:17 AM
ehhh....you guys are prolly right.....well once i get the high flows...if im not satisfied...then back with the stockers...i want the best for the damn vehicle!
Old Mar 20, 2007 | 09:06 AM
Josh2006's Avatar
If you get high flows don't make your decision till you tune it cuz you will still have that smell that is aggravating you and the SES light will still be on.
Josh
Old Mar 21, 2007 | 01:13 AM
but am i hurting the performance of my car???
Old Mar 21, 2007 | 05:26 PM
Dustin's Avatar
No cats! Get an x-pipe made and dump it at your rear, no mufflers, just a straight 3" pipe. The sound is great, the smell is awesome, less weight more power.
Old Mar 21, 2007 | 08:26 PM
chevyhank's Avatar
You can also get rear O2 sims with the high flow cats and that should help the pcm problem.
Old Mar 21, 2007 | 08:31 PM
Ragtop 99's Avatar
if you didn't update your tuning, you now know the source of your problems.
Old Mar 22, 2007 | 12:12 AM
jimmyblue's Avatar
Moderator
You might want to dig a little deeper and not blame it on
two missing bricks. Like maybe one of the sensors got left
unplugged, or something.
Old Mar 22, 2007 | 12:33 AM
aaaahhh that might be true...ill look under the car tomm....anyways...theres this shop that tunes the car for 300...and then dynos it....sounds good
Old Mar 22, 2007 | 12:35 AM
hhhmmm..im most def. going to get x pipes done....is 250 too much???and what do you mean "dump it at your rear?
