Convertible Vehicles Enthusiasts | Information | Maintenance
subframe conectors
Old Apr 9, 2007 | 01:14 AM
droptopT/A's Avatar
Default subframe conectors
should i install subframe conectors or would it make my car heavier and then slowit down but then again it is a vert and it needs them right?
Old Apr 9, 2007 | 01:31 AM
DropTopBird's Avatar
Any of our cars can benefit from SFCs. Yes they will add weight and yes it might slow your car down by an insignificant ammount. You will never be able to tell though, probably not even at the strip. What you will be able to tell though is how much better your car handles.
Old Apr 9, 2007 | 07:52 AM
Ragtop 99's Avatar
verts feel much better with them.
Old Apr 10, 2007 | 02:45 AM
droptopT/A's Avatar
Default wich onces should i get
i would like the lightest ones any body khow which ones are the lightest one they make for a vert thanks
Old Apr 10, 2007 | 09:50 AM
caddobass's Avatar
I don't think you need to worry yourself with the lightless of your subframe connector, as it is there to stiffen the frame & do away with alot of twisting & flex. Just get you a good set ( weld in or bolt in ). I went with BMR weld in.
Old Apr 10, 2007 | 02:32 PM
shiv15's Avatar
As of right now isn't BMR the only company that makes them?
Old Apr 12, 2007 | 04:10 PM
solarofthesix's Avatar
i think SLP makes them for our cars too...not sure....
I would like to get something like the ones they have that look like a diamond and have a removable bar that connects the two sides together....but havent had the luck in finding them for the droptopper yet. Maybe I can get someone to fab up somehting nice
Old Apr 13, 2007 | 03:56 AM
droptopT/A's Avatar
Default isnt umi making some
tubular ones
Old Apr 13, 2007 | 11:14 AM
Shock Hawk's Avatar
Remember to go with 3 point SFC's, not 2 point. 2 point is almost as good, but you might as well put the 3 point in while you're down there.
Don't forget to consider a Shock Tower Brace. I'll help stiffen up the front.
Old Apr 16, 2007 | 12:43 PM
fastmatt98's Avatar
I put some bolt in Don Gontez SFC's and they work great. Stiffened the car up perfectly. I didnt want to weld since its a rare car.
Old Apr 17, 2007 | 06:09 AM
BobDoLe's Avatar
if you google "don gontez" all you come up with is your post on ls1.com.
where do you get these bolt in subframe connectors for convertibles????
Old Apr 17, 2007 | 08:31 AM
jimmyblue's Avatar
Moderator
Goetz is his name, I've seen him mentioned before but
have no idea about the product.
Old Apr 18, 2007 | 12:47 PM
SS30ANV's Avatar
I also put some of Don's SFC's on my 30th Anv. SS convert. Had Don do them in Hugger Orange to match my stripes....love em. I can provide a contact address if you are interested.
Attached Thumbnails subframe conectors-tailpanel-008.jpg   subframe conectors-photoshoot-008.jpg
Old Apr 18, 2007 | 02:30 PM
BobDoLe's Avatar
i found don goetz on chirpthird and hit him up for sfcs and an adjustable panhard with an email.
Old Apr 18, 2007 | 08:00 PM
waSStock's Avatar
could you forward the info to me please...itsstock@netzero.com
thanks
Old Apr 18, 2007 | 11:45 PM
shiv15's Avatar
me too BobDoLe, emails high1015@msn.com
Old Apr 19, 2007 | 08:59 PM
digitalbird's Avatar
ditto could you send that info hear!! bmahoneyjr@comcast.net
Old Apr 22, 2007 | 12:28 PM
BobDoLe's Avatar
i also asked him about a panhard bar
The SFC's are either Red or Black Powder Coat finish and the PHB is Black.
Both are easy to install and the car does not even have to leave the ground.
The PHB is Double-Adjustable, that is to say its length can be adjustable after it is
bolted to the the car. It has a QA1 Spherical Rod End and 4-Link Adjuster on one end and
a pre-greasedPolyurethane Bushing with grease fitting on the other. No picture but I can get
one later today if need be. It's a new product and some of the guys on the Chirpthird Board have
one so if you need testimonials they can provide them.
See attached Picture of the SFC's
i sent him a message to let him know i wanted to post this information on ls1tech. i'll update this if he requests it.
Attached Thumbnails subframe conectors-sfc-vert.jpg   subframe conectors-phb1a.jpg   subframe conectors-phb2b.jpg
Last edited by Ragtop 99; Apr 25, 2007 at 07:30 PM. Reason: Non-sponsor contact & pricing info
Old Apr 22, 2007 | 08:21 PM
Stroker396@APF's Avatar
I found a guy who is on Ebay that is making SFC for convertibles. Full length and they have a the otpion to bolt to the center.
I was looking to go with this setup.
Old Apr 24, 2007 | 02:54 PM
FireHawkMike's Avatar
i ordered bmr's from speed engineering today.
