Convertible Vehicles Enthusiasts | Information | Maintenance
Anyone cut floor to do pump in their vert?
Old Aug 21, 2007 | 09:32 AM
MY99TAWS6's Avatar
Default Anyone cut floor to do pump in their vert?
I want to put pump in my 96z28 but not sure on floor cutting method. Anyone do this method in a vert?
Old Aug 21, 2007 | 10:42 AM
MrDude_1's Avatar
no, i did it by dropping the tank.. took about 2 hours start to finish.
Old Aug 22, 2007 | 11:04 PM
axeman's Avatar
I did it. I think it works great. You can find the info if you do a search on camaroz28.com.
Old Aug 23, 2007 | 12:34 AM
MY99TAWS6's Avatar
So you have a vert axeman?
Old Aug 23, 2007 | 06:26 PM
axeman's Avatar
Yes I do. I just don't post that much on here so i never really bothered to set up my sig. It really isn't that hard and once you have done it you can easily change your pump in 30 min.
Old Aug 23, 2007 | 07:45 PM
jimmyblue's Avatar
Moderator
I asked this question a year or two back and didn't get any
info. If you have done it and have pictures of the final
sheet metal opening I would love to have them for later
when needed.
Old Aug 23, 2007 | 08:13 PM
WS6Drop's Avatar
I would like to see it as well. I asked about this awhile back and someone said its just like the coupes.
Old Aug 23, 2007 | 11:59 PM
redbandit98's Avatar
i did it, not that easy. It makes it a pita because you cant get to the opening as easy due to where the cross piece is on the verts. Just look at where the hole needs to go and youll see what i mean. when you try to pull the pump out, you have to manipulate it in all sorts of ways to get it out. at least thats how it was on mine. Id drop the tank. no questions asked. we cut a hole for one in a coupe, it was cake.
Old Aug 24, 2007 | 07:00 PM
SS30ANV's Avatar
Here's a few links I saved from a year ago showing how to do it.
http://www.worldisround.com/articles/12533/index.html
http://home.bellsouth.net/p/s/commun...eid=224396&ck=
http://www.bfranker.badz28.com/fbody/fuelpump.htm
http://www.taekwondoplus.org/z28/fuelpump.html
Hope this helps......
Old Aug 24, 2007 | 08:22 PM
b1er's Avatar
it works exactly like the hatchbacks...the only thing you have to do differently is compress the bucket assembly springs so it can be removed from the hole you've cut....everything else is the same....I looked at the links above and it seems all those are LT1 cars....the door on mine is much further back toward the rear of the car.....if needed I can go and photo both my vert and hatchback to show the areas that werre cut....
EDIT: found this thread with LS1 pics...pump is further back than the pics above show:
https://ls1tech.com/forums/showthrea...fuel+pump+door
