Convertible Vehicles Enthusiasts | Information | Maintenance
heavy
Old Jun 18, 2008 | 03:03 PM
iwannagofast2000's Avatar
Default heavy
ok so from my understanding convertibles are slower because of all the extra support on the bottom cuz there is no roof is this correct? and my next question say you have around 430 to wheels do you need to build up the bottom any more?
Old Jun 18, 2008 | 03:56 PM
The Manalishi's Avatar
The reinforcments on the convertibles make them heavier but they are not just on the bottom of the car. You should definately get subframe conectors if you are going to mod a convertible. Also if it runs faster then 13.49 you have to have a roll bar to be legal for NHRA.
Old Jun 18, 2008 | 05:38 PM
BobDoLe's Avatar
heavier by about 150lbs. all things being equal (which they aren't because even with the top up, coefficient of drag probably isn't as good), equally modded coupe with small passenger and convertible should run about the same.
Old Jun 18, 2008 | 08:22 PM
cool so subframe connectors thats pretty much all i need as far as reinforcement? thanks guys
Old Jun 18, 2008 | 11:11 PM
topdj-com's Avatar
dont the 2 t tops and that large piece of rear window glass make it about even
Old Jun 18, 2008 | 11:57 PM
z28bryan02's Avatar
Nope, convertibles are more heavy
Old Jun 21, 2008 | 01:47 AM
topdj-com's Avatar
looks like they are about 90 lbs more depending on options, I'm guessing they put serious reinforcement
Old Jun 21, 2008 | 09:51 AM
Ragtop 99's Avatar
If you are going to cut 1.5x 60' SFC may not be enough. When you put in a cage, I'd put it all the way through the floor to the subframe. I noticed a bit of twist on my Z28
Old Jun 21, 2008 | 01:11 PM
Springbirdoo's Avatar
Lightbulb A Londoner's Pride
 A Londoner, very proud of his hometown, was showing a visiting American around Central London.“That's Waterloo Bridge,”he said.“It took only two years to build.”  “That's nothing,”said the American.“Our Brooklyn Bridge took only 14 months.”  Later as they went along the Euston Road, the Londoner said,“That's the Euston Station. The old one demolished and the new one put up in 18 months.”  “Our largest station in New York,”said the American,“was completed in less than 10 months.”  A little later on, they passed Centre Point, looking at its 34 storeys, the American asked,“What's that building?” ..World Of Warcraft gold is WoW gold  “Oh, I don't know,”said the Londoner.“It wasn't there when I went to work this morning.”
Old Jun 21, 2008 | 05:10 PM
GXPPOWER's Avatar
2001 models
Curb Weight: 3,623 lbs. TA convertible
Curb Weight: 3,490 lbs. V6 firebird convertible
Curb Weight: 3,323 lbs Base v6 firebird
Curb Weight: 3,369 lbs. firebird Formula (best potential in terms of weight to power)
Curb Weight: 3,417 lbs. Trans Am t-top
Curb Weight: 3,517 lbs Ws6
though we have a lot more undercarriage re-enforcing we have bad body roll from having not frame up top. verts naturally dont get as good 60fts or launches in general.
Roll cages do work wonders but also add alot of weight to an already heavy car
